Engine Block Coolant Drain Plugs
rexlex
I NEVER do coolant flushes absent a repair that requires it or the coolant degrades beyond the anti-freeze level I require (Seattle area) or if the Ph goes out of whack.
The only exception was that I changed out the factory coolant in my 1992 LS400 about two years ago, 11 years and 100,000 miles, simply because it was looking a little murky.
