Well I'm pretty excited, my first car and its in good condition although recently I experienced something odd...
After driving on the freeway at a constant speed (and using overdrive) for an hour, as I pulled in to the driveway I saw some steam or white smoke coming from the hood. I opened up the hood and it looked like it was coming from the back of the engine. Should I be worried? Also... It has an oil leak and there is oil residue on top of the engine, I've been told by a friend that this can be fixed, is that true?
Well the car is in really good condition though and I really want to customize it like tint the windows and put some cool rims on.
Do you guys have any suggestions for what I could do to this car to make it cooler? Also what rims would fit on it?
One last question...
It has 140000 miles on it, is there anything special I should replace/rotate/change?
Thanks a bunch!
Is that easy to fix? Also I think there is a gas leak, I guess it depends for a gas leak if it's a bad thing right? I'll probably bring it in to get checked.
First off,
Welcome to the club Fezel B) Do you have a reliable mechanic you can yake your ES to? If not, ask friends & family to recommend one. The dealers are quite expensive & yous is very close to a 1990 & 1991 Toyota Camry V6 LE so to repair them is not too difficult. I would make a list of all your concerns & take the car to your mechanic to look over & repair what is needed. Good Luck! B)
As far as customizing is concerned, you have ton's of stuff you can do to your ES from appearance to performance. I would suggest tint, front strut tower brace, a complete tune up is important & the like to start off with. Many more things can be done down the road depending on your tastes & budget. ;)
:cheers:
Thanks, ya I'll be looking for a good mechanic to check it out and tune it up. I was thinking of getting chrome rims, would you happen to know what sizes fit on 1990 es 250?
Try going to www.tirerack.com, go to 'upgrade garage' & select wheels for your year & model of ES. Let me know if you need assistance down the road with tires as well. B)
Post some pics of your new ride when you can.
:cheers:
Ill have to find a camera, but ya ill post some pics of it. Thanks for the link I'm checking out the chrome tires right now :).
