Maximaboy1 Posted August 5, 2005 Posted August 5, 2005 hi I have a 95SC400 with 107K miles..the car, when I accelerate from a stop in the 0-40 mph range, the engine or something makes a kinda clicking sound...it might be knock, since i do pump 87 gas into it...any suggestions? It doesn't sound like knock though...
texsn95 Posted August 5, 2005 Posted August 5, 2005 hiI have a 95SC400 with 107K miles..the car, when I accelerate from a stop in the 0-40 mph range, the engine or something makes a kinda clicking sound...it might be knock, since i do pump 87 gas into it...any suggestions? It doesn't sound like knock though... ← Yeah, it's called "pinging" or "detonation". These engines require higher octane fuel for a reason. Why skimp and risk damage to your pistons? An extra $4 per fillup is well worth the piece of mind. Go run some 93 in it and monitor it.
Maximaboy1 Posted August 5, 2005 Author Posted August 5, 2005 a good point i need to make first...this sound is intermittent.
DomLee Posted August 5, 2005 Posted August 5, 2005 Yes, your octane is too low. (Did you not see the "Premium" fuel required sticker on the car?) From there...if you are still getting a sound....then it will be time to look into other things. But for right now, purchase higher octane gas.
Sadistic Posted August 5, 2005 Posted August 5, 2005 I agree, Octane is probably the cause of the issue, but i have a question. Is the sound extremely loud at start up?
Maximaboy1 Posted August 5, 2005 Author Posted August 5, 2005 it's most noticeable at startup and then decreases in loudness as the engine warms up.
DomLee Posted August 5, 2005 Posted August 5, 2005 BTW...consider siphoning the 87 octane out of your gas tank if you have a lot of it. If only a little,...fill up w/ 91 octane and you'll be fine.
texsn95 Posted August 5, 2005 Posted August 5, 2005 If the good gas doesn't change it, then it's probably some valvetrain noise. Does it increase with idle? Have you even popped the hood to listen to it? Does it do it when you floor it? More when it's hot out? Need a little more info here...
Maximaboy1 Posted August 6, 2005 Author Posted August 6, 2005 It makes the noise when I accelerate, even flooring it. It doesn't have a temperature variant. I'll use 91 the next time and see.
ptownTSI Posted August 22, 2005 Posted August 22, 2005 if its pinging, why the hell are you flooring it. thats the absolutely worst thing you could do. run 91 until it goes away, then when the tank goes down fill it back up with 89, then when it goes back down to 1/2 fill it back up with 91. thats about the only reasonable plan you could do to save money. you are damaging your lexus putting 87 in it and running it like an idiot.
Smartazz91 Posted August 31, 2005 Posted August 31, 2005 I've never used anything less than 93 in my 93 SC300. It's a 5spd with 255k miles on it. What sounded like pinging during acceleration turned out to be an exaust leak. The first pipe coming off of the manifold rusted. The part was around $250. Not the V-8. But, worth looking at. Hopefully, it's just the gas.
DayWalkerSC400 Posted August 31, 2005 Posted August 31, 2005 hiI have a 95SC400 with 107K miles..the car, when I accelerate from a stop in the 0-40 mph range, the engine or something makes a kinda clicking sound...it might be knock, since i do pump 87 gas into it...any suggestions? It doesn't sound like knock though... ←
