1st Gen Gs300, Do You Love It?
i am seriously thinking about getting this lexo.
just want to know what you guys think about it.
any thing i should look out for?
thanks so much
I love my 96 GS300 I will be replacing the steering pump this week end, the pump is working fine but the bearing is making a funny noise :(
Win
The mk1 is a great car the engines are nearly bullet proof,they can have Headgasket trouble,just watch for suspension wear mainly on the Front upper wishbone arms they arent cheap to replace!! If you push and pull on the front wheel there should be no movement,if there is you will see the movement on the arm above the wheel.Also check the footwells to make sure the carpets are dry,if the carpets damp then the heater matrix is on its way out,the labour charge wont be cheap to get it replaced.
Good luck if you decide to buy one.
Cheers chips.
