AppleJack Posted July 12, 2005 Share Posted July 12, 2005 For a 1992 SC400 - Does anyone know what ERROR CODE 15 represents?? (I changed my ignition cables and moved a few odds and ends - and now my car starts but then shuts off right away) Quote Link to comment Share on other sites More sharing options...
JamesN Posted July 13, 2005 Share Posted July 13, 2005 I think it rep an Ignition signal. You should try to check for loose cables and replug it. Hope this help, good luck. Quote Link to comment Share on other sites More sharing options...
AppleJack Posted July 13, 2005 Author Share Posted July 13, 2005 Hmm - anybody else have anything more specific? I actually have to communicate this to a friend who has my car - and am not sure what they have loosened off to get access to change the ignition wires ... Quote Link to comment Share on other sites More sharing options...
dcfish Posted July 13, 2005 Share Posted July 13, 2005 Hmm - anybody else have anything more specific? I actually have to communicate this to a friend who has my car - and am not sure what they have loosened off to get access to change the ignition wires ... ← 12 RPM Signal 13 RPM Signal 14 Ignition Signal 15 Ignition Signal 16 Electronically Controlled Transmission Control Signal 17 CMP No. 1 18 CMP No. 2 21 Main O2S & Heater Signal 22 ECT Sensor Signal 24 IAT Sensor Signal 25 Air–Fuel Ratio Lean Malfunction 26 Air–Fuel Ratio Rich Malfunction 27 Sub O2S Signal 28 Main O2S 29 Sub O2S 31 & 32 Air Flow Meter Signal 35 HAC/Barometric Pressure Sensor Signal 41 TP Sensor Signal 42 VSS Signal 43 Starter Signal 47 Sub TP Sensor 48 Secondary Injection System Malfunction 51 Switch Condition Signal 52 KS Signal 53 Knock Control Signal 55 KS Signal 70 EGR System Malfunction 71 EGR System Malfunction 78 Fuel Pump Control Quote Link to comment Share on other sites More sharing options...
AppleJack Posted July 16, 2005 Author Share Posted July 16, 2005 thank for your help . My friend took everything apart again and put it back together and then it worked ... must have goofed up a connector or something.. this is the 50th time I've learned this lesson .."if there is something simple and straight forward to do on your car - then do it yourself, because no one will be as careful and gentle on your car as YOU would be!!" Quote Link to comment Share on other sites More sharing options...
