rhkwon Posted July 9, 2005 Share Posted July 9, 2005 OK, I've got a 1994 ES300 with 80,000 miles on it. A few months ago, I had the Vac thing done where they clean out everything. Now I noticed that at start up there is white smoke coming out and that there is a noticeable lack of power in first gear (automatic trans). At speed and downshifted, the lack of power is still there. Once warmed up, it seems fine but still seems a little low on power. Plugs have been changed, etc. I'm thinking it may be the O2 sensor. Any ideas guys? This is driving me frickin crazy! Quote Link to comment Share on other sites More sharing options...
Icemaninlv Posted July 11, 2005 Share Posted July 11, 2005 mine does the same thing. look at your distributer and ohm it out mine was bad between ne and g1 the crank and cam signals not correct. does the smoke smell like gas. if so ohm your distributer pickup coil out. Quote Link to comment Share on other sites More sharing options...
rhkwon Posted July 11, 2005 Author Share Posted July 11, 2005 mine does the same thing. look at your distributer and ohm it out mine was bad between ne and g1 the crank and cam signals not correct.does the smoke smell like gas. if so ohm your distributer pickup coil out. ← Thanks a lot for the info. I'll check into it. Quote Link to comment Share on other sites More sharing options...
SKperformance Posted July 11, 2005 Share Posted July 11, 2005 clean your maf Quote Link to comment Share on other sites More sharing options...
