Drivers Side Window Only Rolls Down Halfway
vwdee
Recently my drivers side window stoppped rolling down all of the way. I have ruled out the window regulator/motor being bad. I have looked around the door panel to see how to take it off but since i don't have a manual, I figured I would get another opinion before I broke anything.
Has anyone taken the door panel off and what is the best way to do so?
Well, seeing as I was searching on this topic I am going to be doing it tonight because a friend held the button down to long and it sounds like it broke off track, I'll let you know how it turns out, wish me luck.
Ok you can go look here also http://us.lexusownersclub.com/forums/index...showtopic=20953 for instructions.
It turns out that the metal rod right in the middle of the door contains the lifting mechanism. If you watch closley when rolling the window up and down you can see it move past each tiny whole up and down the rod. Now my problem is its not catching the window when going up, it only catches going down, and I can't figure out the problem. Its hard to see on the other side on the inside of the window. If anyone has any answers or ideas please let me know! thanks!
SirSam:
I think your problem is related to the white plastic (teflon) traveler that rides in
the metal guide (rod as u eluded to).
Here's basically what happens when u roll the window up and down:
There are two separate cables which wrap around a plastic capstan (pulley like
mechanism) in oppsite directions, then pass thru conduit guides and end up
being molded into the teflon traveler--ea cable has a small metallic cube attached
to its end. What probably happened is the cable that pulls the window down broke
loose from the traveler. This is what happened in my case.
There is a writeup.. either this or another lexus forum, can't remember.. which
outlines a fix by using epoxy (JB weld in this case) to fasten the cable back onto
the traveler but it is not an easy task. You have to remove the regulator, bend
the guide mechanism open to remove the traveler, clean and rough up the plastic
surfaces and do the mend job and hope it holds.
I elected to buy a new regulator, about $120 including shipping from Lansing Mi.,
rather than go thru the mend process.
Removing the regulator/motor was not that difficult: remove the three nuts that
hold the guide rod and three nuts that hold the motor end both attached to the
metal door panel. The reg/motor can then be worked free. Your new regulator,
if u chose to go that way, will come with a black plastic case covering the capstan
and wrapped cables. The black cover is for a very good reason. Do not remove
the cover.. its purpose is to hold the cables in their position so you can slide the
new capstan into the old motor housing without losing the tightly wrapped cable
which seem to be under tension. Just place the open end of the new capstan over
the square motor shaft and rotate the shaft to allow the capstan to slide into the
housing. Replace the new matallic cover over the capstan and u are ready to
reinstall the unit.
I had a bit of a problem with the reinstall. I could not for whatever reason get the
the horizontal guide attached to the window to mate with the teflon traveler...
I just couldn't seem to find the proper angle to slide it into the groove so iI finally
just filed the high points of the oblong teflon part of the traveler so I could tap it
into the guide. It did not affect the window operation even tho I remove a good bit
of plastic.
So far, over a week, the window has performed quite well.
Hope this helps and good luck,
Lexie
I'm going to just buy a new regulator. Every site I've found that has a parts catalog does not have that part. Could you possibly give me the site you got yours off of?
SirSam--
The regulator I got for around $120 was for a '93 SC400 passenger side.
The parts dealer is Spartan Motor Mall located in Lansing MI
ph# 1 800 333 8696 or 1 800 998 7557.
I have bought several Lexus parts there and have been quite satisfied
with their pricing. Ask for Gary and tell him the guy from Pensacola who
just ordered the regulator a few weeks ago recommended your parts
outlet and hopefully he will treat you right re the cost of the part. Have
your VIN # handy and specify whether driver or passenger side. Delivery
for me was abt 4 days.
Whenever I price parts at the regional Lexus dealers in this area, the
parts costs are significantly higher. This place seems to be consistently
lower.
Hope this helps,
Lexie
  • 1 month later...
