While in reverse and the car moving the tranny disengaged. After that it would not go into any gear. Has anyone experienced this? There were no other warning signs, the tranny has 326km on it. The car is religiously dealer serviced. The tranny fluid looks good. The engine light didn't come on so there are no codes from the Computer.
I am pulling the tranny out and taking it to a shop for an estimate.
Does it even try to go in gear?
It sounds more like the selector mechanism has broken. I've run across that problem more than once.
The Neutral saftey switch could also be broken. That has a tendancy to happen.
I would try pulling the gear selector switch out the outside of the transmission to find out if works before you go pulling the transmission.
