I recently changed my third brake light in my 1999 ES 300 and the little orange car light on the display disappeared but then when my lights are turned on it returns. I don't see any brake lights out in the back or any parking lights. Does a Lexus dealer need to reset this or what should I do. How many lights are there on the back of the lexus that I would need to check?
Thanks
It must be one of the lights that only comes on with the tail and parking lights.
Did you look at you license plate lights, there are two in the back, maybe one is out. Also look at all of the side marker lights.
steviej
i don't think the blown light ecu measuers the other lights resistance or amperage draw other than brake ones
it is probably a cheap bulb with a weird filament inside used for replacing cause the ecu to get bad readings
