Ron O Posted May 28, 2005 Share Posted May 28, 2005 I feel that the Nav screen is not as “bright “ as I would like. I notice that on sunny, bright days (not in direct sun) the screen is washed out even with the adjustment of the display screen and the colors. I live in Western NY State so I would imagine that the southern owners would have even more complaints, The dealer says that the screen is normal. Quote Link to comment Share on other sites More sharing options...
LexKid630 Posted May 28, 2005 Share Posted May 28, 2005 When i had my 2003 rx300 i too noticed that the nav screen was dim. It also had a lot of glare even IF the plastic was non-glare. The only thing i could do was put my hand over it LOL. Quote Link to comment Share on other sites More sharing options...
indiasfinest Posted May 29, 2005 Share Posted May 29, 2005 well idk if all the nav systems are the same but in the GX you can go to display and adjust it....try switching to night mode....the contrast and brghtness can help 2. :D Quote Link to comment Share on other sites More sharing options...
patt Posted May 29, 2005 Share Posted May 29, 2005 Our screen is fine for readability and contrast even in bright sun. The one problem I have is that it isn't as bright as I would like when viewed through my sunglasses so I end up lifting them for a second if I really need to see the screen well. The sunglasses are pretty dark. Quote Link to comment Share on other sites More sharing options...
indiasfinest Posted May 29, 2005 Share Posted May 29, 2005 only one solution..new sunglasses...lol Quote Link to comment Share on other sites More sharing options...
RXinMN Posted May 31, 2005 Share Posted May 31, 2005 With the sunroof open, the sky reflects directly into the Nav screen making it nearly impossible to see. If only the angle were a little lower... I've also found that polarized sunglasses can blank out the screen completely. If you turn your head about 45 degrees to the left, it will blank out... and it's also pretty hard to drive straight, too. I don't recommend it. Quote Link to comment Share on other sites More sharing options...
