I ordered a set of brembo rotors from Nopi and the fronts went on fine w/ no problem but Ive ran into a problem w/ the rears... When I look at my old rotors it looks like the axle nut comes thru the rotor and bolts on over the rotor... The problem is the rotors that Nopi have a huge axle hole and there is no lip for the axle nut to bolt onto... I called nopi and they said send them back and I have to pay the shipping unless I can show them they are listing the wrong rotors on their site... I plan on calling Brembo but figured it wouldnt hurt to ask if anyone else has ran into this problem... Oh and I guess it would help if I mentioned my car is a 94 sc400
Here is the url for the nopi shocks
http://www.nopionline.com/nopistore/dsp_pa...%20SC400%201994
The rotors fit snug over the hub. Spray with PB Blaster of WD40 and let it sit for awhile. You'll probably have to persuade the rotor off the hub with a big hammer. Read the following: Rear rotor
their are bolt holes on the rotors hat which you screw a bolt from the brake caliper into it and it will bang the hat off the hub very loudly in one crack
