Power Window Problem!
byrd
Hi guys!
I'm new to the forum.
Can anyone help me with my 95 SC300 powered windows problem?
The pass side controller works fine, but the driver side is not working at all
i can't roll up or down the windows at all! either driver or passenger side,
the door lock switch is working fine, I also did check the motor for the driver side windows it's OK :cries:
I have done a search but did not find anything as of yet..
Hi guys!
My driver window on 95 sc300 just went out too..guess it's an age thing!
Just got my new switch and it didn't help. On to the next step. Maybe the motor or possibly a wire issue. I may just end up taking it to the dealer. I am in Florida and it is too stinkin' hot to be driving around with only the sunroof and one window working.
I had the same problem. First I bought a brand new switch, no help. Then I got the wiring diagram and shot the wires. Found a bad ground, so I jumped it and everything worked fine. That worked for about six months then the window failed again. I wound up taking it to the dealer and they replaced the driver's side harness.
  • 1 month later...
taadow77--
Lexie here. I am repairing my passenger side power window. I have a regulator
on order and already removed the door panel in prep of removing the existing
regulator.
My questions:
What steps did you go thru to remove the old unit. The motor/regulator unit seems
to be in a tight spot. Was there a problem in unhooking/re-hooking the electrical connection.
Was the window in the down position when you installed the new regulator.
Any and all comments would be most appreciated.
I have a '93 SC400.
Thx,
L
