branshew Posted April 11, 2005 Share Posted April 11, 2005 I have an instrument cluster on eBay now (that I used for temp when I had my original out to fix the needles). The mileage reading is 164XXX miles I received a question from a bidder in relation to the odometer going over 200K. He inicated that he was told that you would have to get the odo reset back to 0 at 200K miles and Lexus would put a sticker on the door frame to indicate that 200K needs to be added to the reading? I had never heard this and that doesn't really make sense to me - otherwise why have the six digit odometer. I thought the first digit would read anything in the 0-9 range depending on the miles. I have yet to be over 200K in a Lexus and the only ones I can find on eBay with over 200K are early LS 400s with the analog odometer. Can anyone confirm or disprove this? Quote Link to comment Share on other sites More sharing options...
blake918 Posted April 11, 2005 Share Posted April 11, 2005 I've never heard of a dealer doing that before. <_< I found this picture of Maine92ES's car in the highest mileage thread.... Quote Link to comment Share on other sites More sharing options...
ArmyofOne Posted April 11, 2005 Share Posted April 11, 2005 I've never heard of a dealer doing that before. <_< I found this picture of Maine92ES's car in the highest mileage thread.... ← heh, my contour did this with an analog odometer. It read all the way up to 299,999 miles and then rolled back over to 000000. i was shocked! i called ford and asked if it was normal, they said they didnt know becaue they had never seen a contour go that far. i pulled it out and apart and sure as *BLEEP*, the last digit only went up to 2, when it came time to roll around to 3, it went back to a 0! weird... finally i asked around int he contour owners club locally here where a few members have reached over 300K, and they all had the same issue, so i determined it must be normal. i just had to make sure that at every inspection the odometer reading was reported as having a 3 in front of it, i didnt want the carfax report coming back with a damn inaccurate reading! Quote Link to comment Share on other sites More sharing options...
SKperformance Posted April 12, 2005 Share Posted April 12, 2005 The elctornic ones should go over to 999 999 before roll over Quote Link to comment Share on other sites More sharing options...
Pistol Pete Posted April 13, 2005 Share Posted April 13, 2005 I have 209,xxx on my 97 ES300 and no issues with the odometer. Quote Link to comment Share on other sites More sharing options...
