One of my friends told me that the IS starts in 2nd gear to meet claiforni smog laws. I live in Texas. Is the true, if so is there away to bypass this???
Never heard of that. The shifter and the Eshift only indicate a 2nd position, but the car still takes off in low.
You should be able to tell what it's doing by taking off from a standstill and counting shifts.
2nd gear starts are for snow
We got a snow button for that. I don't believe you can force a 2nd gear start with the gear selector, with an IS300.
I don't know about californian laws - but on the IS's and GS's I have driven with E-Shift, you cannot shift down to 1 manually.
This may give the impression that the car pulls away in second gear.
However, in auto, an e-shift mode, the car will start in 1st.
The manual selection of the gear is the same as on a standard autobox.
The gear selected in the highest gear the car will move up to - not the gear it starts in.
If you select 3 on your auto gearbox, it doesn;t start it in 3rd does it.
Exactly. :cheers:
