cincinnaticats03 Posted April 3, 2005 Share Posted April 3, 2005 I need help installing Redline Strobe lights into my 1990 LS400. I want to install the lights into my fog light area. The lights are U-shaped and come with different colored covers. Instructions in the book are to: 1. Drill a 3/4" hole where the strobe light will be inserted. 2. Place control box in accesible location inside car 3. Connect positive wire to a 12 V source that is protected by a 3 - 5 Amp in line fuse. 4. Connect negative wire to good ground source I do not understand this, can someone put it in simple terms? Thanks Quote Link to comment Share on other sites More sharing options...
Meist21 Posted April 3, 2005 Share Posted April 3, 2005 I need help installing Redline Strobe lights into my 1990 LS400. I want to install the lights into my fog light area. The lights are U-shaped and come with different colored covers. Instructions in the book are to:1. Drill a 3/4" hole where the strobe light will be inserted. 2. Place control box in accesible location inside car 3. Connect positive wire to a 12 V source that is protected by a 3 - 5 Amp in line fuse. 4. Connect negative wire to good ground source I do not understand this, can someone put it in simple terms? Thanks ← Srobe lights WTF are you putting strobe lights on there for? Quote Link to comment Share on other sites More sharing options...
VMF Posted April 3, 2005 Share Posted April 3, 2005 if you dont mind me asking, why would you want to do that? Quote Link to comment Share on other sites More sharing options...
GSsoldier Posted April 3, 2005 Share Posted April 3, 2005 haha someone must be bored... im guessing u are using it to mess around with people at night Quote Link to comment Share on other sites More sharing options...
VBdenny Posted April 3, 2005 Share Posted April 3, 2005 To do this you would have to remove the headlight and foglight assembly. From there, I suppose you could drill and 3/4" hole in the back and then insert the bulbs. Then run you wires, good lucking finding a place through the firewall. I sure wouldn't do this because it will probably mess up the foglights and be a pain to wire. Do you park near the airport a lot? Quote Link to comment Share on other sites More sharing options...
92silverls400 Posted April 4, 2005 Share Posted April 4, 2005 you better check with your State DMV: regarding putting strobe lights on your vehicle. Hate to see your LS400 get impounded for impersonating a law enforcement officer. then you have to take everything apart and waste your money :cries: :chairshot: Quote Link to comment Share on other sites More sharing options...
GSsoldier Posted April 4, 2005 Share Posted April 4, 2005 i dont think theres any state that allows personation of a cop car... but in the headlights would make it a lot easier to hide vs. just on your dash or something... VB- why would it matter if he was near a airport or not?? Quote Link to comment Share on other sites More sharing options...
Lexls Posted April 4, 2005 Share Posted April 4, 2005 Don't bother, it's illegal. Don't even put them inside your LS. Quote Link to comment Share on other sites More sharing options...
914lps Posted April 4, 2005 Share Posted April 4, 2005 I can tell you that unless they are "law enforcment" rated that the strobes are a joke. In daylight they can not be seen. At night not that great. If you are adding them to actavate with your alarm. No one is going to pay extra attention to the car when it strobes. It is a lot of work on your car to get then in right. And then you make an opening for water. You will end up with fogging in your lights. If you need them for emergancy responce then go on ebay and look at getting a real emergancy light like Federal Signail. If it just something for fun.... It is your car to do with as you please.... Be it seen by others as a good idea or bad. Quote Link to comment Share on other sites More sharing options...
