RedRocket Posted March 16, 2005 Share Posted March 16, 2005 My 99 SC400 is developing an intermittant starting problem. I twist the key and hear a click but no crank. Usually a second or third twist will get it going. After reading the post here, I believe my starter is going. I have the Lexus manuals that say removal of the intake manifold is needed, along with a bunch of other things. Anyone got any helpful hints on the process or on getting new parts, like gaskets. Thanks Glen Quote Link to comment Share on other sites More sharing options...
Shadow Posted March 16, 2005 Share Posted March 16, 2005 Make absolutely sure your battery is good prior to working on the starter. Quote Link to comment Share on other sites More sharing options...
cheeff Posted March 16, 2005 Share Posted March 16, 2005 I had a similar problem with my 93 sc 400, but when I took it to the shop it turns out the problem was with the terminals connected to the battery. All I ended up doing then was changed the terminals, so check the terminal along with the battery. Cheeff :D Quote Link to comment Share on other sites More sharing options...
Lextreme Posted March 19, 2005 Share Posted March 19, 2005 I have a tutorial on the starter replacement. It will take you 6 hours. www.lextreme.com/starter.html david I had a similar problem with my 93 sc 400, but when I took it to the shop it turns out the problem was with the terminals connected to the battery. All I ended up doing then was changed the terminals, so check the terminal along with the battery.Cheeff :D ← Quote Link to comment Share on other sites More sharing options...
RedRocket Posted March 20, 2005 Author Share Posted March 20, 2005 YES, I got it already. Please contact me privately. My Lextreme user name is the same Redrocket . Thx Glen :D I have a tutorial on the starter replacement. It will take you 6 hours. www.lextreme.com/starter.html david I had a similar problem with my 93 sc 400, but when I took it to the shop it turns out the problem was with the terminals connected to the battery. All I ended up doing then was changed the terminals, so check the terminal along with the battery.Cheeff :D ← ← Quote Link to comment Share on other sites More sharing options...
