mig25 Posted June 23, 2003 Share Posted June 23, 2003 :( 1990 LS400 Leaking oil :( I recently found out that my LS400 is dripping oil by the front of the transmission, behind the support beam. There are two 12mm bolts, it is where is dripping. It is motor oil. Is there an oil seal where the transmission meets the engine? Or there is some sort of gasket inside that little plate where the two 12mm bolts are? Any clues or advise? thanks. Quote Link to comment Share on other sites More sharing options...
mig25 Posted July 1, 2003 Author Share Posted July 1, 2003 OK folks, this is an update for the problem listed above... After a long research, I found out the oil leak was from the Engine rear main oil seal. I replaced the seal and the problem seems to be solved. :D Quote Link to comment Share on other sites More sharing options...
