jadecuir Posted February 24, 2005 Share Posted February 24, 2005 Anyone out there know where to find an original pioneer sub for '90 LS400? P/n 86160-50010. It's a 2 ohm, 8" sub, probably in the 40 watt range. My son put a 100 watt, 8 ohm Kicker in, but the amp will barely drive it. I would like to find a used original or aftermarket comparable sub to balance out the system. Quote Link to comment Share on other sites More sharing options...
99lsguy Posted February 24, 2005 Share Posted February 24, 2005 Check out the Stereo/Audio forum...... Look for and PM "Pioneersbuy".........he will know. Quote Link to comment Share on other sites More sharing options...
Lexls Posted February 26, 2005 Share Posted February 26, 2005 You can get a new sub but it will be super expensive. You can also get a used sub but I do not recommend that because they are almost always broken or ready to break. See the info here: http://www.lexls.com/subwoofer.html The 4 ohm sub in that tutorial will be better than an 8 ohm sub. Basically, you're just trying to install the closest match possible. An 8 ohm sub is not the closest match ;). Unfortunately 2 ohm subs are very rare so the 4 ohm sub is the ticket. Quote Link to comment Share on other sites More sharing options...
jadecuir Posted February 26, 2005 Author Share Posted February 26, 2005 You can get a new sub but it will be super expensive. You can also get a used sub but I do not recommend that because they are almost always broken or ready to break. See the info here: http://www.lexls.com/subwoofer.htmlThe 4 ohm sub in that tutorial will be better than an 8 ohm sub. Basically, you're just trying to install the closest match possible. An 8 ohm sub is not the closest match ;). Unfortunately 2 ohm subs are very rare so the 4 ohm sub is the ticket. ← Thanks for the info. I'll look for a 4 ohm, 40 watter.john Quote Link to comment Share on other sites More sharing options...
jmwgomz Posted February 27, 2005 Share Posted February 27, 2005 Lexls, great info! I just found out about this forum yesterday and I already did the woofer adaptation that you recommended. It worked like a charm. Thanks a lot! I had to use a different woofer because the Kicker model has been discontinued. I used a CerwinVega. Jeez, I had forgotten what a difference that woofer made. Thanks again! Quote Link to comment Share on other sites More sharing options...
Lexls Posted February 27, 2005 Share Posted February 27, 2005 Hey, I'm very happy to help you guys out :D I kinda figured that Kicker sub was not available anymore. The guy that submitted that tutorial did it a long time ago. Quote Link to comment Share on other sites More sharing options...
LexDiamondLS400 Posted February 27, 2005 Share Posted February 27, 2005 Hey jadecuir I dont know if ur still looking for that subwoofer?? But I recently purchased a '90 LS400 and im going to re-do the entire radio system, so all the stock speakers are trash as far as im concerned. The radio doesnt work in my car which is another reason im replacing it, plus im stereo fanantic. But I am pretty sure that it works and is in pretty good shape, so if ur still looking u could have mine free of charge. Just pay for the shipping and its urs. If u want i could send u a pic of it. Quote Link to comment Share on other sites More sharing options...
jadecuir Posted February 27, 2005 Author Share Posted February 27, 2005 Lexls, great info! I just found out about this forum yesterday and I already did the woofer adaptation that you recommended. It worked like a charm. Thanks a lot! I had to use a different woofer because the Kicker model has been discontinued. I used a CerwinVega. Jeez, I had forgotten what a difference that woofer made. Thanks again! ← Where did you get the CerwinVega, and how much was it? Do you have part/model # and specs? Quote Link to comment Share on other sites More sharing options...
jadecuir Posted February 27, 2005 Author Share Posted February 27, 2005 Hey jadecuir I dont know if ur still looking for that subwoofer?? But I recently purchased a '90 LS400 and im going to re-do the entire radio system, so all the stock speakers are trash as far as im concerned. The radio doesnt work in my car which is another reason im replacing it, plus im stereo fanantic. But I am pretty sure that it works and is in pretty good shape, so if ur still looking u could have mine free of charge. Just pay for the shipping and its urs. If u want i could send u a pic of it. ← That would be great! Email a pic and where/how to pay shipping, and the money is on the way! jadecuir@comcast.net John DeCuir Salinas, CA Quote Link to comment Share on other sites More sharing options...
jmwgomz Posted February 27, 2005 Share Posted February 27, 2005 The speaker I used was a Cerwin-Vega HED-8. This speaker does not come with the plastic piece that that is used to mount the speaker in the tutorial. You need to use the black molded plastic ring that is on the original speaker. I thought that it was glued on so I broke it when I was tryint to remove it. It is actually held together by four small screws. You need to remove the foam that is glued to the bottom of it to uncover the screws. If you have any problems, send me a PM. Quote Link to comment Share on other sites More sharing options...
AzHotLS Posted April 12, 2005 Share Posted April 12, 2005 John, Did you get the subwoofer from LexDiamond? I'm in the same boat (or should I say plane) as you are/were. If not, LexDiamond, I'm interested if you still have it. Anyone else got a spare sub they're willing to part with? Ken Quote Link to comment Share on other sites More sharing options...
jadecuir Posted April 12, 2005 Author Share Posted April 12, 2005 John, Did you get the subwoofer from LexDiamond? I'm in the same boat (or should I say plane) as you are/were. I recently bought an Audiobahn sub on ebay, and I'm going to see if it fits right now. Lexdiamond said his was trashed, when he got to looking at it. I'll tell you how the new sub works and what the number is if it fits and works. It's 2 to 8 ohms, depending on how you wire it. John Quote Link to comment Share on other sites More sharing options...
AzHotLS Posted April 12, 2005 Share Posted April 12, 2005 Thanks. I look forward to hearing how you make out. In a previous thread, somone mentioned finding an open box deal at a store, so that's what I've been trying to do, no luck yet. At the risk of sounding cheap, I'd like to get one for about $50. Quote Link to comment Share on other sites More sharing options...
jadecuir Posted April 14, 2005 Author Share Posted April 14, 2005 Thanks. I look forward to hearing how you make out.. ← Well, I put in the Audiobahn AW831T sub the other day. You can wire it up for 2 to 8 ohms, parallel or series. I tried both ways, and parallel seems to work better, but it's still weak. I think the sub is capable of over 100 watts, and the little Pioneer Amp just won't drive it like OEM. I need to find a lower wattage sub, but they're hard to find nowadays. An aquaintance of mine owns a stereo shop, and he says all he sells anymore are these huge thumpers for the hiphop crowd. Quote Link to comment Share on other sites More sharing options...
GSsoldier Posted April 16, 2005 Share Posted April 16, 2005 hello everyone been reading the post trying to find that Cerwin-Vega sub cant seem to find it any where... any ideas? also if i just hooked up an audiobahn 8 in is there a way to power it by aftermarket amp so it can get feed the correct amount of power? Quote Link to comment Share on other sites More sharing options...
jadecuir Posted April 16, 2005 Author Share Posted April 16, 2005 hello everyone been reading the post trying to find that Cerwin-Vega sub cant seem to find it any where... any ideas? also if i just hooked up an audiobahn 8 in is there a way to power it by aftermarket amp so it can get feed the correct amount of power? ← I'm sure that any car stereo installation shop can sell you an amp, and wire it up for you. ebay will save alot of money, but you'll have to do it yourself. Did you wire it up this way?CarDomain___Woofer_Wiring_Guide.html Quote Link to comment Share on other sites More sharing options...
GSsoldier Posted April 19, 2005 Share Posted April 19, 2005 hey guys is it possible to hook up aftermarket to the stock 93 deck? cus if it is let me know guys i see a hella good deal for an 8 in sub... i read lexls's site and i understand he has a aftermarket deck... if i do replace the sub with an aftermarket sub thats needs more then 40 watts... would i have to change wires? i know i would have to change amp too -joe Quote Link to comment Share on other sites More sharing options...
GSsoldier Posted April 20, 2005 Share Posted April 20, 2005 still searching for cheap subs no luck yet crutchfield doesnt carry one that is same spec wise as the kicker on lexls.com i cant seem to find a 2, i can only find a 4 and 8 ohm sub -joe Quote Link to comment Share on other sites More sharing options...
harjp Posted April 22, 2005 Share Posted April 22, 2005 You can buy mine. I'm installing a Alpine system. Found someone who will make a faceplate to replace the trapezoid shaped piece of plastic that covers the Pioneer radio. I won't be using the subwoofer, which I had installed for $400 14 months ago because the old one burned out. How much you want to pay? Harry Quote Link to comment Share on other sites More sharing options...
GSsoldier Posted April 23, 2005 Share Posted April 23, 2005 what kind of sub? im trying to keep under budget... its been reduced by a lot Quote Link to comment Share on other sites More sharing options...
