camlex Posted February 24, 2005 Share Posted February 24, 2005 Hello, I was getting some noise when i start after breaking or stopping at light. Mechenic told me front and rear mounts need to replace. Is it easy? How much money we talking? Thanks, Quote Link to comment Share on other sites More sharing options...
es300ed Posted February 25, 2005 Share Posted February 25, 2005 I don't know if this is your problem or not but I just failed inspection because of a "dog bone" mount. Lexus wanted $180 to replace it. I had it done by my trusted local shop for $81. I didn't notice any noise due to the cracks in the dog bone mount so it may not be your problem. Ed Quote Link to comment Share on other sites More sharing options...
1995_ES300 Posted February 25, 2005 Share Posted February 25, 2005 the only prob with my dogbone mount is that the rubber grommet is partially cracked an is free-spinning around the bolt, it still serves the purpose for now... Quote Link to comment Share on other sites More sharing options...
khhoang Posted February 25, 2005 Share Posted February 25, 2005 if you feel/hear a slight clunk or jerk of the engine when shifting from Park-Neutral-Reverse-etc then that's a sign of a torn bushing in the dogbone mount (~$30part easy DIY in minutes). if the dogbone bushing is torn then another engine mount is also suspect (most likely the front engine mount visible under the oil filter ~$150part DIY couple hours if you're mechanically inclined). there are a few engine & transmission mounts.. so find out which ones exactly your mechanic pinpointed. Quote Link to comment Share on other sites More sharing options...
camlex Posted February 27, 2005 Author Share Posted February 27, 2005 Thanks, If my car is stopped and I begin to accelerate. sometimes in my steering wheel I feel a very little clunk or tap. I took it to the mechanic, he held the breaks and accelerated in the drive position and the other technician was looking at the engine. He did it a couple of times and the engine was shaking, but no noise was coming. Then he put it in reverse and he accelerated, and again the engine was shaking up and down and no noise came. When I talked to people they said the engine is supposed to move up and down and if you don't hear any noise the mounts are fine. Is that correct? in front you have two mount . one looks like shock and other is fat mount. which one is dogbone mount ? Quote Link to comment Share on other sites More sharing options...
SKperformance Posted February 27, 2005 Share Posted February 27, 2005 search Quote Link to comment Share on other sites More sharing options...
camlex Posted February 27, 2005 Author Share Posted February 27, 2005 Sk, Thank you. Search give me some idea. Also created some question. Some place you mentioned " i rebuild them using urethane and they last and are much stronger " Will you please clarify? Quote Link to comment Share on other sites More sharing options...
camlex Posted February 27, 2005 Author Share Posted February 27, 2005 Sk, I found it. 3M windo-weld superfast Urethene 08609 $13 from O reilly. It's in. how much time for curing? so i can install it back Thanks, Quote Link to comment Share on other sites More sharing options...
camlex Posted February 27, 2005 Author Share Posted February 27, 2005 (edited) Hello, 3M windo-weld superfast Urethene 08609 $13 from O reilly. It's in. how much time for curing? I did install it back but how long i should wait to drive my car.? Thanks, **please note: this thread has been merged with a thread containing the exact same question. steviej** Edited February 28, 2005 by steviej Quote Link to comment Share on other sites More sharing options...
amf1932 Posted February 28, 2005 Share Posted February 28, 2005 Hello,3M windo-weld superfast Urethene 08609 $13 from O reilly. It's in. how much time for curing? I did install it back but how long i should wait to drive my car.? Thanks, ← It sets up in about 24 hours ....depending on ambient air temperature. To be sure, I would call up 3M to check it out. Quote Link to comment Share on other sites More sharing options...
SKperformance Posted February 28, 2005 Share Posted February 28, 2005 Window weld breaks down over time. You mgiht get a better chance of doing it by applying it in layers over a week for each layer to cure Quote Link to comment Share on other sites More sharing options...
camlex Posted February 28, 2005 Author Share Posted February 28, 2005 Hello, I started driving.. No problem no noise. Quote Link to comment Share on other sites More sharing options...
SKperformance Posted March 1, 2005 Share Posted March 1, 2005 I didn't have problems for a few months either until it fell apart from the inside Quote Link to comment Share on other sites More sharing options...
camlex Posted March 1, 2005 Author Share Posted March 1, 2005 Hello, I thought about it. That's reason bought From autozone part no 8201 for $36.00. two washer 3/8 from home depot $0.24. Done. Autozone has lifetime warranty. Thanks, Quote Link to comment Share on other sites More sharing options...
