hey , just wondering what would be the cost for front and back brake pads installed?
and how much do OEM brake pads cost alone ? i m thinking abut buying them and taking it to shop to install. so they dont install me some crap kind .
i hope i would not need the rotors resurfaced, i guess that would be another 30 bux front and 30 bux back?
thanx
To get a good idea of what is needed to change the brakes check the workshop tutorials as i made a post their for relavent info.
Pads are about $60 each
new rotors are about 100 each
so 520 for all new brakes with great quality Canadian prices
so about 400-450
It only takes 30 minutes per corner so 2 hours max to change all 8 pads and 4 rotors.
2 x $60 for local technition 120
or about 90 from lexus 180 for labour.
check my Photo Tutorial in the Maintenance section, its pinned at the top.
the process is for the ES250 but the ES300 is the same (or close).
You can PM me with any questions you might have.
if you cant use the PM feature yet, email them to me:
armyof1_2006@Remove_me_First_yahoo.com
if you are not likely to do the work yourself and have an independent that will allow you to bring in your own parts, then get the parts online.
here are the prices from irontoad.com
BRAKE PADS
Front 0446533121 $34.94
Rear 0446632010 $35.64
Rear 0446632050 $34.94
DISC ROTOR
Rear 4243133010 $79.30
Front 4351233041 $73.47
Rear 42431-33060 $78.81
steviej
thanx guys, I probably would not be doing it my self since its snowing in NYC again hehe and i never done my brakes on any cars, even though i worked on my talon for a while. was afraid of its rust ; )
anyways, how come the back have 2 diff part #s and is that OEM?
i would probably not need the rotors, since mine look new, i just hope iw ould not have to resurface them
thanx again
Ilya
Ilya
yeah, they are Toyota/Lexus OEM parts from a large Lexus dealership in PA. They do a nice online distribution job too. I have used them in the past with no problems and their prices are as good as any online Lexus parts dealer.
another site is www.lexus-parts.com and www.newlexusparts.com
I haven't a clue why the two item numbers for the rear. You would have to call or email irontoad.com for a good answer.
steviej
the reason why the rear is a different # is because of the size difference from the front brakes and the rear, thus making them different. :D
I think the question was why are there two different part numbers listed for the rear, not why is there a different part number for the rear.
steviej
