lexdog Posted February 19, 2005 Share Posted February 19, 2005 I recently came accross a cold intake for a RX300. I was wondering if anybody tried cold intake for there lexus. And if so if they believed it increase performance ? Or what there opinion is on cold intake ... B) Heres a pic http://www.weapon-r.com/store/html/images/swintake2.jpg http://www.weapon-r.com/store/agora.cgi?ca...n&ppinc=search2 Quote Link to comment Share on other sites More sharing options...
RX400h Posted February 19, 2005 Share Posted February 19, 2005 The term "Cold Air Intake" is often misconstrued. True cold air intakes draw outside ambient air into the engine's intake. The air is unaffected by the temperature of the engine bay. Vehicle manufacturers typically try to balance low noise with high flow and adequate filtration, so be aware that many "high-performance" intake systems are noticably louder than OEM systems. The advantage is that more air is able to be drawn in, resulting in more horsepower. The intake you mention claims to increase both volume and velocity of incoming air. Increasing the velocity does tend to cool down the air. I installed an aftermarket intake (huge air filter) and fabricated my own cold air inlet and scoop in my Corvette. That and a cat-back exhaust system increased my rear wheel horsepower by 13 (as measured on a dyno). Noise levels are definitely higher, but then again, I figure that's what most expect out of a Corvette! Quote Link to comment Share on other sites More sharing options...
ColinBarber Posted February 19, 2005 Share Posted February 19, 2005 not heard great things about weapon-r customer service. Quote Link to comment Share on other sites More sharing options...
SKperformance Posted February 20, 2005 Share Posted February 20, 2005 Weapon R is garbage. It fits so it works no R&D. An aem for a similar year camry will work also Besides that intake shown is not even cold air it is the worst most rice part you can add to an engine. It draws heated air not cooled air into the engine resulting in lower gas milage, lower hp and increased carbon. SO go cold air or nothing. The only other best option is to remove the water ballast/muffler from under the air filter box, this will result in a good amount of gains with now worries of injesting water and only a slightly more deeper intake noise. This is free to do and requires no modifications only removing it. BTW the intakes only make more noise at wide open throttle normal driving is just as quiet Quote Link to comment Share on other sites More sharing options...
Elucid Posted February 20, 2005 Share Posted February 20, 2005 It's Almost impossible to put a nice intake in it :( Quote Link to comment Share on other sites More sharing options...
SKperformance Posted February 21, 2005 Share Posted February 21, 2005 Why is that elucid? Quote Link to comment Share on other sites More sharing options...
TunedRX300 Posted February 21, 2005 Share Posted February 21, 2005 I recently came accross a cold intake for a RX300. I was wondering if anybody tried cold intake for there lexus. And if so if they believed it increase performance ? Or what there opinion is on cold intake ... B) Heres a pic http://www.weapon-r.com/store/html/images/swintake2.jpg http://www.weapon-r.com/store/agora.cgi?ca...n&ppinc=search2 ← Better off just take of the resonator and extend an pipe to where resonator is since it is outside the engine bay. I dislike short ram intake since it sucks in hot air and foam filter breaks down over time, guess where those broken foam pieces are going to. Quote Link to comment Share on other sites More sharing options...
linisys Posted March 8, 2005 Share Posted March 8, 2005 I was looking into the AEM. SK mentioned that a Camry of similar year would be compatible, but the AEM website: http://www.aempower.com/product_intake.asp doesn't seem to have that. Does anyone have any other suggestions? (besides not doing this). I tend to agree that the Weapon-R is a bit too rice. Kinda scary about that FOAM... What about replacing the W.R. cone with the AEM filter head instead? Best of both worlds perhaps? Quote Link to comment Share on other sites More sharing options...
TunedRX300 Posted March 8, 2005 Share Posted March 8, 2005 I was looking into the AEM. SK mentioned that a Camry of similar year would be compatible, but the AEM website: http://www.aempower.com/product_intake.asp doesn't seem to have that. Does anyone have any other suggestions? (besides not doing this). I tend to agree that the Weapon-R is a bit too rice. Kinda scary about that FOAM... What about replacing the W.R. cone with the AEM filter head instead? Best of both worlds perhaps? ← I would go for K&N, which is cotton with a nylon mesh. I have Comptech Icebox for my Acura, it has a foam filter which I will replace with K&N RU2590 Universial Cone Filter when it is due for cleaning. Not sure it will fit for Weapon R but you need to measure pipe diameter and find the right one. www.ajusa.com has the best price with free shipping. Again, personnally I would not buy short ram. A K&N drop in filter, removing the resonator, and extending a pipe to collect cold air to where resonator was probably give you more hp for less $. Quote Link to comment Share on other sites More sharing options...
