lex-o-951 Posted February 2, 2005 Share Posted February 2, 2005 Can the HID bulbs be replaced with aftermarket HID bulbs? If i want to change my bulbs for my HID's to 10,000k bulbs would that damage my electrical? Quote Link to comment Share on other sites More sharing options...
steviej Posted February 2, 2005 Share Posted February 2, 2005 who makes a 10K k HID bulb and how much illumination is that going to give you? I'm guessing it is going to be purple and a candle will through more light. the k number is the kelvin temp. not anything to do with amps. or watts. As long as you don't go higher than the stock wattage rating, you should endanger any wiring. steviej Quote Link to comment Share on other sites More sharing options...
SKperformance Posted February 2, 2005 Share Posted February 2, 2005 oem bulbs need to be replaced with oem bulbs their are some knocking around but they don't last as long and the actual light output is crap Quote Link to comment Share on other sites More sharing options...
bartkat Posted February 2, 2005 Share Posted February 2, 2005 Don't go with anything that uses more than 35 watts anything higher will screw your wiring and lighting system, sooner or later. . Sure, you can find crappy bulbs at high color temps, but like the guys above have said, you won't see *BLEEP*. Also in some states you'll get busted with running with those kind of headlight. OEM are around 4000 to 4200K and after long use may go up to 4500K. Anything over 5000K on a Lexus is RICE, IMHO. Quote Link to comment Share on other sites More sharing options...
SKperformance Posted February 3, 2005 Share Posted February 3, 2005 actually bart i really like 6300k bulbs much whiter ,no yellow and barely a touch of blue 800k is just ridiculas ,sure it is brighter than halogen still but why compare an apple to a rasin. Quote Link to comment Share on other sites More sharing options...
bartkat Posted February 3, 2005 Share Posted February 3, 2005 actually bart i really like 6300k bulbs much whiter ,no yellow and barely a touch of blue800k is just ridiculas ,sure it is brighter than halogen still but why compare an apple to a rasin. ← Your preference is fine if that's what you like. It is however a fact that color temps above 4300 or so will produce less lumens. For my purposes, lumens is where it is at. :) Quote Link to comment Share on other sites More sharing options...
supdawg240 Posted February 4, 2005 Share Posted February 4, 2005 just cahnge it it will catch people eye Quote Link to comment Share on other sites More sharing options...
