I just recently bought my 2000 gs300. Well I took it to get an oil change the other day, and the mechanic said that i have a toyota supra engine and parts under the hood. what do you make of this? i don't really understand cars so i don't know if i should panic or not? :unsure:
Could you post a picture of the car. It will be better if you take a picture of the engine and post it here.
From whom did you buy the car from (Dealer / Individual)? Didi you run a CarFax prior to purchase?
Herk
yes you do have a toyota supra engine.  You have a late 2jz-ge model engine.
Minus the turbo's, of course B) :D
that's why I mentioned the 2JZ-GE engine code
2JZ-GE = NON TURBO
2JZ-GTE= TWINTURBO
Thank u :D I was just worried...because when I got it, it had only 35000 miles on it. I didn't carfax but I bought it from a dealer. I will post a picture of the engine when I get the chance to. As long as everything is ok. Thank you all for ur replies.
2JZ-GE = NON TURBO
2JZ-GTE= TWINTURBO
I know that, but the poster might not have <_<
No need to post, unless you just wanna show it off, as we've all seen the engine B)
Please post the pix , Then we will have seen the engine !!!! ;)
The GE is nowhere near the GTE. The head is totally differenty, rods, pistons and oil squiters. He is excited seeing a 2jz?
JPI
your car should've came stock with the supra motor and parts, so itz normal, the SC300 and i thinkg the LS300 is like that too :whistles: not sure about the LS300 but the SC300 im sure, but you have nothing to worry about.
