I notice considerable body roll on turns and corners in my 92 ES300, can I get a noticeably improved handling by going from factory 15x6 to 16x6 rims? Right now I have Michelin Energy MXVP+ tires.
noticable in that small of a change no
17's yes or 18s definatly
but the springs are the first order of buisness to change they are high on roll
What kind of springs do you suggest? And how much would it cost parts and labor? I don't want the suspension to be too firm, just something in the middle. I don't want to feel all the bumps in the road yet I would like to minimize the body roll.
Also I've heard the michelin x-ones have a stiffer sidewall that most tires. This should also help minimize body roll, if I decide not to change the springs. Right?
your sidewalls would account for maybe 10% of the roll
eibach make a nice kit calle d the pro kit
about 400 installed for the states i am guessing
you can keep the orignal shocks but it is only a 1 inch drop
and a much firmer feel with a smooth ride
Tires won't help body roll much. If you go with just springs without performance shocks, you'll probably just get lots of bounce. Pro Kit springs would be fine, but I'd suggest adding KONI or other adjustable shocks or I don't think you'll be happy with the ride. With Koni Sports you can tune in the ride and handling to suit yourself.
However if you are just going to do one thing, good shocks will help your handling more than just springs or just tires. Judging from the age of the car, it may need shocks anyway.
it is possible
but i feel more of a difference in cornering from a stiffer spring than a stiffer dampener
i just put my kyb's in today with new springs and they are great
much smoother than the eibachs with stock struts
but i did like the ride initally
but i love it more now
How much do the KYB shocks go for? Also are there different types to choose from (damping factor) for the 92 ES300?
Sprins, sway bars and wider tires. all of these would help out the roll problem..
i do not know what the retail price is for them in the US
check a local performance shop
they only make one kind
unless you have servicable struts but i don't think it is in the 92 ones
they are ( as i am told )
one of the smoother shocks for the mcv10 chasiss compared to tokico and others
an alternative might be the monroe sensa trac with new springs
might be cheaper
will 215/55 tires fit on a 16x6 rim? or do I have with a wider rim?
sk, i checked out the kyb website, do you have the Gas-a-Just or the GR2 shocks?
