AusJapanWindom Posted June 13, 2003 Posted June 13, 2003 Ok, guys.. Have decided to go with the chrome Lexus badges, as my car is a 2 tone silver and grey under belly.. Thought the gold wouldnt look as good.. Anyways.. I need to remove the Toyota badges, and need every single bit of information that could help me before i remove them.. Any suggestion will be great!.. I have a 1996 model Windom.... Skyperformance, you have helped me heaps in the last few days.. so thank you... Chris
AusJapanWindom Posted June 14, 2003 Author Posted June 14, 2003 Anybody else have anything to Ad.... What glue or sealant do you use to put the badges back on? Chris
bartkat Posted June 14, 2003 Posted June 14, 2003 I have used the 3M double faced moulding tape, the kind with the red backing. Just take the tape and cut little pieces to fit on the back of the emblem stick them on the emblem and trim as needed. Then clean the area for the emblem with rubbing alcohol and stick it on. Press against the emblem for about 30 seconds to a 1 minute. I did this on another car and it was still in good shape after more than a year.
SKperformance Posted June 14, 2003 Posted June 14, 2003 glad to help to remove use dental floss it helps to do it easy also a hair dryer or a nice hot day helps to loosens the glue up a pre wax cleaner willhelp to remove the rest i posted the same thing about the 3m stuff i the other post a second ago
