mitymouse Posted December 21, 2004 Share Posted December 21, 2004 http://cgi.ebay.com/ebaymotors/ws/eBayISAP...mMakeTrack=true I'd like to put these on my 99 GS300. I think they'd be a massive improvement in handling over the 16's I have now but 245 would probably be a better width. To bid or not to bid, that is the question. The 225's would still be wider than what I've got and I know the low profiles and W rated tires would whoop my H rated Firestone Affinity LH30s (balloons)... What do ya think y'all? I could keep the 16's handy for long road trips. Quote Link to comment Share on other sites More sharing options...
SKperformance Posted December 22, 2004 Share Posted December 22, 2004 225 is fine hell it is for my small car Quote Link to comment Share on other sites More sharing options...
SAMOHT023 Posted December 29, 2004 Share Posted December 29, 2004 http://cgi.ebay.com/ebaymotors/ws/eBayISAP...mMakeTrack=trueI'd like to put these on my 99 GS300. I think they'd be a massive improvement in handling over the 16's I have now but 245 would probably be a better width. To bid or not to bid, that is the question. The 225's would still be wider than what I've got and I know the low profiles and W rated tires would whoop my H rated Firestone Affinity LH30s (balloons)... What do ya think y'all? I could keep the 16's handy for long road trips. ← THAT TIRE IS MUCH TOO SMALL FOR THAT APPLICATION. THE MINIMUM TIRE I'D GO WITH ON THAT VEHICLE IS A 245/40/18. I THINK YOU WILL SACRIFICE HANDLING AND VEHICLE STABILITY WITH SUCH A SMALL TIRE. I NORMALLY INSTALL THAT SIZE TIRE ON HONDA ACCORDS AND ACURA CL'S. I HAVE A 93 SC400 WITH 18X8.5 ON THE FRONT AND 18X10 ON THE REAR. I RUN A 245/40/18 ON THE FORNT AND 275/35/18 IN THE REAR. THE HANDLING AND RIDE QUALITY IS EXCELLENT. Quote Link to comment Share on other sites More sharing options...
maaloxx Posted January 5, 2005 Share Posted January 5, 2005 http://cgi.ebay.com/ebaymotors/ws/eBayISAP...mMakeTrack=trueI'd like to put these on my 99 GS300. I think they'd be a massive improvement in handling over the 16's I have now but 245 would probably be a better width. To bid or not to bid, that is the question. The 225's would still be wider than what I've got and I know the low profiles and W rated tires would whoop my H rated Firestone Affinity LH30s (balloons)... What do ya think y'all? I could keep the 16's handy for long road trips. ← THAT TIRE IS MUCH TOO SMALL FOR THAT APPLICATION. THE MINIMUM TIRE I'D GO WITH ON THAT VEHICLE IS A 245/40/18. I THINK YOU WILL SACRIFICE HANDLING AND VEHICLE STABILITY WITH SUCH A SMALL TIRE. I NORMALLY INSTALL THAT SIZE TIRE ON HONDA ACCORDS AND ACURA CL'S. I HAVE A 93 SC400 WITH 18X8.5 ON THE FRONT AND 18X10 ON THE REAR. I RUN A 245/40/18 ON THE FORNT AND 275/35/18 IN THE REAR. THE HANDLING AND RIDE QUALITY IS EXCELLENT. ← definately go with 245/45/18 for the GS. Quote Link to comment Share on other sites More sharing options...
Neo Posted January 6, 2005 Share Posted January 6, 2005 THAT TIRE IS MUCH TOO SMALL FOR THAT APPLICATION. THE MINIMUM TIRE I'D GO WITH ON THAT VEHICLE IS A 245/40/18. I THINK YOU WILL SACRIFICE HANDLING AND VEHICLE STABILITY WITH SUCH A SMALL TIRE. I NORMALLY INSTALL THAT SIZE TIRE ON HONDA ACCORDS AND ACURA CL'S. I HAVE A 93 SC400 WITH 18X8.5 ON THE FRONT AND 18X10 ON THE REAR. I RUN A 245/40/18 ON THE FORNT AND 275/35/18 IN THE REAR. THE HANDLING AND RIDE QUALITY IS EXCELLENT. ← definately go with 245/45/18 for the GS. ← Actually 245/40 would be closer to spec. 245/45 would be about 1" too big. Quote Link to comment Share on other sites More sharing options...
