My 2002 RX300 navigation screen suddenly dropped down in brightness.
I know about the dash dimmer and the brightness and contrast controls - it is not either of those. I took the car to the dealer and they did not have another vehicle to compare it to - both the service person and the sales person thought it looked okay after the brightness and contrast were put to their extreme settings. I am frustrated by this, since I use the nav everyday and it really irritates me to have a darker image. Anyone know how to address this? I called Lexus headquarters and they told me to just bring the car to another dealership, but that there is no way to measure the brightness as a diagnostic.
Have you tried changing the screen color? The nav screen changes color based on season, when it does this some people think the screen dims.
How do you do that?
Try turning the contrast down about halfway....
I was amazed at mine, high contrast, poor visibility.
If you go into the menu screen you'll see choices for color, there are 4 choices and then a "AUTO" button where it changes based on season.
I don't think mine has an auto button. Maybe that was new in the 330s.
I have noticed mine seems to be dimmer in the colder weather.
Tom
Here's pictures from my RX300. After doing this, it might solve your problem
First press the MENU button on the NAV
Then Press the SETUP
Scroll down and you should see something like this, change MAP COLOR and see which one suits you best. Remember to Press OK to save the changes
Good Luck
- Robert
Good Luck
- Robert
Wow! I can not believe you took the trouble to take pictures. That was so nice.
I do not have that same system. My "MENU" screen does not have those same options. I will show it to the dealer though. My map version is 2001 v, but I don't think that would be the reason for the menu differences.
Once again, that was so nice of you, thanks.
Hey LexusBoston,
Your Welcome, :D I hope you'll get ur problem solved after having the dealer checks it out.
Good luck :)
Ran into a similar issue last week.. the screen was dark(unreadable)... in the morning.
All the settings in MENU were Auto. I hadn't changed anything the night before.
After a few minutes of trying... I changed the HEADLIGHT KNOB to 'AUTO'. I had switched that off.. and this screen switched to the 'Day' mode.. and was the usual brightness.
I was surprised.. what all was driven by the 'Auto' setting of the headlight knob.
hope urs was something simple like that.
mine's a 2001 RX300.
Sounds like your headlights or parking lights were on.
Once you put it back in Auto, the lights went off because it was the daytime and your screen changed back to day mode.
  • 17 years later...
http://members.aol.com/rlrx300/12-17-04nav/image01.jpg
http://members.aol.com/rlrx300/12-17-04nav/image02.jpg
http://members.aol.com/rlrx300/12-17-04nav/image03.jpg
Good Luck
- Robert
I am having the same issues with my 2002 RX 300 dashboard not bright or not showing sometimes unless I restart my engine, I wanted to use your picture description solution but the pictures are not coming up can you help me with that I would really appreciate it
