Check Engine Light
yudelia
Hello to all - I have a '97 LS400 with 115,000 flawless miles. However, recently the check engine light has pemanately illuminated while the engine is running. All the fluids are OK and the engine sounds and performs perfectly. Would appreciate any and all advice... Thanks
How could you possibly determine that the O2 sensor is malfunctioning based on just the check engine light?
There is a POSSIBILITY of O2 malfanctioning because Yudelia metioned engine sounds and runs perfectly.
For older cars mostly the check engine light are related to air/fuel ratio IF the engine sounds and runs perfectly. I had the same experience. :)
