Sticking Emergency Brake On 96 Es300?
Mr Bill
My wife just brought the car back after leaving for work this morning, saying "it felt funny" and that the emergency brake light was on, and when she put the handbrake down, the light stayed on. She drove it home and when she put the car in park, the emergency brake light went out. She also insists that she had released the handbrake before she set out on her trip to work.
My questions are: do the emergency brakes on this car stick on?? Is the idiot light connected to the parking brake Handle (as I would guess), or some other part of the system? i.e. if the light was on, must the handle have been up?
My wife has confessed to driving this car with the handbrakes applied before. The car also has bad juddering when applying the foot brake at speed, I can't really tell if its the back brakes or the front brakes causing it, or both. So I guess I need new rotors etc etc. Do you have a replacement set you recommend???
Thanks for any feedback,
Mr Bill
Mr Bill
:D just replace you wife and you will not have these problems :D
somehow i didn't find that funny.
Most brakes will stick if not used.
Their is no way to easily see the brake shoes and drum as it is inside the rear rotors hat.
Might need to get your brakes checked anyway to remove the pulsating from warped rotors.
Many places do it for free.
The light is connected to the amount of fluid in the container
how could u not find that funny? replace the wife everything is good :D
and the light on my ebrake is connected to the foot pedal. and that cable directly drives the brake shoes inside the rotor/drum in the rear
The emergency brake cables probably needs to be changed. They can bind due to not using this brake. I had the same problem on a Honda Prelude I owned, and when I replaced these cables everything was back to normal.
P.S. The indicator light indicates low brake fluid level, and also has a switched link which is activated mechanically by the emergency brake lever.
It has been my experience that the most common reason for this light being illuminated is low brake fluid. The reservoir may appear to be full or close to full; however, just adding a bit of fluid often turns off the light. The fluid level sensor is apparently overly sensitive.
Aha - now I get it. The light came on due to low brake fluid - I had no idea it had such a feature. So the brake wasn't stuck (we use the brake all the time), its just that the fluiid is low. Thank you - :cheers:
The brakes need major work anyway, and this is just another indicator that I need to get the work done.
Does anyone recommend specific rotors and pads?? I am somewhat handy - have replaced disc pads before on other cars - would it be overly complex for me to change out the rotors and pads myself (I don't have a manual).??
Your choice of pads and rotors should be based upon your driving style. If you want a factory feel then you should stick with OEM parts...it's hard to go wrong with OEM.
It's very much a DIY job. Try this link to the tutorial: http://us.lexusownersclub.com/forums/index...10822&hl=brakes
Toyota/Lexus brake fluid level sensor is very sensitive. Just top it off an it is usually fine. Even though the level is visually above the low mark, addition of fluid usually settles the light illuminaiton saga.
if you want quiet and dustless and more of the same of what you are used to, get rotors and pads from online Lexus parts dealers.
www.irontoad.com www.lexus-parts.com www.newlexusparts.com
as for a manual, if you have a 97-01 ES, the Haynes manual is acceptable and can be had on Amazon for about $20. The procedure is similar to most disc brakes.
The tutorial thread is a gem.
steviej
