IronWorker Posted November 15, 2004 Share Posted November 15, 2004 Replaced the MAF sensor (97 ES) as per the dealer notice on the cause of the engine light being on (no cracks or holes seen in the pipe or intake areas). Restarted to the engine 3 times to reset, but it did not. The engine light is still on. Any ideas? Quote Link to comment Share on other sites More sharing options...
Thienn Posted November 15, 2004 Share Posted November 15, 2004 What was the error code? Quote Link to comment Share on other sites More sharing options...
SKperformance Posted November 15, 2004 Share Posted November 15, 2004 then take off the battery tterminals it takes 3 system runs of driving the car not just turning the key to rest the light. Quote Link to comment Share on other sites More sharing options...
steviej Posted November 16, 2004 Share Posted November 16, 2004 or, if you don't want to lose your radio presets and stuff, pull the ECU fuse. steviej Quote Link to comment Share on other sites More sharing options...
IronWorker Posted November 16, 2004 Author Share Posted November 16, 2004 then take off the battery tterminalsit takes 3 system runs of driving the car not just turning the key to rest the light. ← This worked, thanks alot. :) Quote Link to comment Share on other sites More sharing options...
IronWorker Posted November 16, 2004 Author Share Posted November 16, 2004 or, if you don't want to lose your radio presets and stuff,pull the ECU fuse. steviej ← I have the manual, so I'll look for that fuse for next time. Thanks for the tip :) Quote Link to comment Share on other sites More sharing options...
IronWorker Posted November 16, 2004 Author Share Posted November 16, 2004 What was the error code? ← This is the type of dealer that wouldn't be interested in providing that type of info - since they know what I was looking to do (fix it myself). It was difficult enough trying to get the correct the name of the part in question. They also don't tell you if the part is under warranty as I have learned from the past. But thanks for the direction. :) Quote Link to comment Share on other sites More sharing options...
