Need Help-1995 Es Seat Problem
chuckb
The driver seat on my 95 ES all of a sudden will not work right. All of the adjustment function work except for one.
The bottom of the seat in the back will not move up and down anymore. The front of the seat still goes up and down, but the back(like where your butt sitts) will not move up or down It makes noise when you push the button, but that's it.
Anyone know what the prob could be?
Thanks
chuckb
I have same issue, i bet its one of the wires that goes to the motor thats broken
I doubt if it's a broken wire, since he said, "It makes noise when you push the button, but that's it."
If the wire was broken it wouldn't make any sound at all. :huh:
i would say that you should take the 4 bolts out of the seat and lean it out the door. then have someone hit the switch, and you sit in the pasanger seat and look under the seat. i would bet the motor moves (because you said it is making noise) and the output shaft moves, but the threds on the output shaft is stripped.
