Where Is Rx330 18" Tire Pressure Sensors?
LexusRXLover
Hi,
I had really bad luck day. :cries:
I just drove over a brick on express way(45mph). The brick damaged one of my rim and tire. I can not believe a piece of brick can damage my rim.
18" Alloy Wheel is a piece of junk. Never dirve over anything....
I did not get new rim and tire yet. But I am wondering where is the tire pressure sensor? Is it inside of tire?
If someone knows about it please show me..
Thanks
Hi,
I had really bad luck day.:cries:
Thanks
Yes the sensor is inside the wheel. You should not run into any problems, just swapping it onto the new wheel.
  • 6 months later...
The sensor is made as part of the valve stem.
A good tire shop can remove a tire without breaking the sensor.
Most shops unfortunatly cannot remove them safely
Sorry guys -- it's not that sophisticated. The 'tire pressure sensor' is nothing more than a smoke and mirrors trick. It's actually an application of the ABS and traction control sensors. They use these sensors to notice a wheel rotation differential -- meaning, if one wheel is consistently spinning at a slightly different rotation than the other wheels, it means that the tire pressure is 'low'. That's all it really is.
It doesn't matter what tires or rims you have -- there are no magic sensors which are affected by tire/rim changeouts.
- CrashNBurns
