Foglight/headlight Aim
are my fogs supposed to be aimed higher than my headlights? I aimed my car at my garage about 20 feet away. my headlight beams (low) were probably 2-3 feet from the ground, but my fogs were closer to 4 1/2 feet high. Is this normal? If not, how do you aim the fog lights? I heard there is a screw somewhere under the car but I don't know for sure. Do they have left/right up/down adjusters like the headlamps do?
oh also I just remembered, I just read that the 94-96 tails will fit a 93, but I also read that the lighting was updated. Does this mean you have to rewire things to get the newer ones to work or are they just plug and play?
thanks!!
Edited by chrispiss
the fogs are not directional the braket must be bent
the tails are a slightlydifferent desing with 2 brake bulbs in 95-96 while their are 3 in the 92-94 so you would need to add a resistor to get the light on the dahs from saying a bulb is burnt all the time.
