dprimo Posted September 19, 2004 Share Posted September 19, 2004 I noticed the engine sounding kind of loud about a week ago. Today, I was at a stop light with the car running fine. When I started to go the car was REALLY loud...sounded like I was Paul Sr. riding one of my custom Choppers. The car seems to be lacking some power when gas applied and is running very loud. Is this an exhaust problem? Any help would be appreciated.....and how much $$$$ am I looking at? Thanks in advance!!!!! Quote Link to comment Share on other sites More sharing options...
dprimo Posted September 19, 2004 Author Share Posted September 19, 2004 Any help out their tonight? Quote Link to comment Share on other sites More sharing options...
steviej Posted September 20, 2004 Share Posted September 20, 2004 have you checked your exhaust? Open the hood and see if the noise is really loud in the engine bay. Have someone rev the motor while you are looking. Put you hand over the end of the tail pipe and see if it feels like there is any air coming out. If not, it is most likely coming out of a leak or hole in the exhaust somewhere. Take it to Midas for a free estimate. steviej Quote Link to comment Share on other sites More sharing options...
SKperformance Posted September 20, 2004 Share Posted September 20, 2004 Your y pipe is broken about $250 for a lexus part $50-100 labour for 6 bolts to be undone do not buy an aftermarket one. Your dogbone is broken causing it to also break the ypipe now. Quote Link to comment Share on other sites More sharing options...
dprimo Posted September 20, 2004 Author Share Posted September 20, 2004 My mechanic can't look at it until tomorrow. Will I do any further damage driving it for a day? Quote Link to comment Share on other sites More sharing options...
SKperformance Posted September 21, 2004 Share Posted September 21, 2004 no Quote Link to comment Share on other sites More sharing options...
lbinh Posted September 21, 2004 Share Posted September 21, 2004 Might be far fetched but check your ignition wires and if they are seated correctly and installed in the correct firing order. A loose connection will lead to a disconnect and that cylinder not firing. Causing the car to loose power and sound like a "chopper." If the car does not fire cylinders in the correct order then you will have loud exhaust nosies and loss of power. Check the wires. Quote Link to comment Share on other sites More sharing options...
