Magata Posted September 17, 2004 Posted September 17, 2004 I have a 99 GS3 - recently, when I started to brake, the brake light comes on and then when I release the brake, the light goes out. The brake fluid is between min and max and I do not notice any braking problems. Any ideas?
SKperformance Posted September 18, 2004 Posted September 18, 2004 Add some more fluid to get it to max. it may bemoving and setting of the light in the resevouir. Does it come off when you are at a full stop?
newport Posted September 18, 2004 Posted September 18, 2004 I had the same thing, It was a brake light bulb. still worked but going black on its glass, so bulb on its way out. replaced bulb all good again, lexus lamp monitor warns you before the lamp fails :D Phil
Magata Posted September 21, 2004 Author Posted September 21, 2004 SK, The light appears to go on when traveling down hill and goes off on an up hill. And yes, it does go off at a stand still. My mechanic thinks it needs fluid and I would agree. Thanks for your response.
