ArmyofOne Posted September 7, 2004 Share Posted September 7, 2004 i found a set of rims that look good on my new car: http://elitrix.net/everythingauto/album_pic.php?pic_id=327 thats just a quick photoshop, they wont be that big, but 17X7. what size and brand do you guys reccomend??? i do a mix of city and highway/wet and dry roads. comfort is not nessecarily the priority here, treadwear and grip are a concern, but grip is the biggest concern. it has to grip. and for under $200 a piece if possible. Quote Link to comment Share on other sites More sharing options...
silvermate Posted September 8, 2004 Share Posted September 8, 2004 just do a search for "tires" its been covered numerous times in depth.......you will find what u are looking for ;) Quote Link to comment Share on other sites More sharing options...
ArmyofOne Posted September 9, 2004 Author Share Posted September 9, 2004 k :) Quote Link to comment Share on other sites More sharing options...
Lexusfreak Posted September 9, 2004 Share Posted September 9, 2004 What is the exact size tires you will need & I can better suggest a specific tire for you. B) Quote Link to comment Share on other sites More sharing options...
ArmyofOne Posted September 11, 2004 Author Share Posted September 11, 2004 205, 70 r15...try that one, i think thats right. Quote Link to comment Share on other sites More sharing options...
Neo Posted September 12, 2004 Share Posted September 12, 2004 205, 70 r15...try that one, i think thats right. Huh? How are you going to fit a 205/70r15 tire onto a 17x7 rim? If you are saying your current OEM tires are 205/70 then ... With x7 rims, I'd stay with 215 or 225 wide tires. 215/55 would be the exact have outside diameter as your OEM size, which is a good thing. If you want the wider tire, 225/55 would be 0.4" taller in diameter. If you are not planning to lower the car, this should be OK. 225/50 would be 0.4" shorter in diameter. Both will throw off your speedo/odo. Pick your poison. Good luck. Quote Link to comment Share on other sites More sharing options...
ArmyofOne Posted September 12, 2004 Author Share Posted September 12, 2004 ah, you are right *hits himself over head*:chairshot: they are 215-40-R17 i believe. Quote Link to comment Share on other sites More sharing options...
