Wiper Issues...
Lex3486
I noticed this morning that my wipers refused to go back into their hole after I'd used them. Could it be that my motor is dying? With a little help from my hand they went down, but they couldn't do it on their own. This is the first time it's ever happened...they still operate normally other than that though... :huh:
the wipers have two positions, exposed and retracted. It's in the manual.
Somehow they may have been moved into the exposed position. You physically move them between the two poitions with your hand. The exposed is designed for winter use, to aid in snow removal.
The retracted postiton puts the blades just under the edge of the hood.
steviej
In the '93ES you have to change the position of the connector on the wiper motor to make it either retract fully or above the hood. It's not a mechanical operation like it is on the newer ES's. I don't know how this connector position changed by itself, so it could possibly be what SK said in the above post.
