only advantage to getting the Supra LSD, if you can find one, is the Torsen. If youre going to do any racing, then its better to get a 1 way or better
yea the supra lsd is a torsen type lsd and its not quite as reponsive as a mechanical lsd so for racing it wouldnt be best. but for daily driving its probably the best becasue it doent make noise
well when one of the tires under power looses traction the tire spins the opposite way with a normal diff. with an lsd there is some locking mechanism wheather it be mechanical, fluid or whatever which keeps this tire that has lost traction spinning in the same direction. simply said thats what it does.
