Has anyone replaced motor mounts on '95 es 300? How many are there including trans mounts ?
How many labor hrs should I expect.
Thanks
Also-just curious? How long do your motor mounts usually last?
I searched on "DOGBONE", a common name for the one motor mount on the ES that is user replaceable. I searched: 365 days and newer and in ES forum. These threads came up.
Pinned: Tells Us About Your Car And Its Mods Or Problems
Find out common problems + repair costs Lexus ES300 / ES330 Forums skperformance 14 4331 Aug 12 2004, 04:41 PM
Last Post by: tckcumming
Transmission
Lexus ES300 / ES330 Forums one30boy 7 174 Jul 13 2004, 08:52 PM
Last Post by: skperformance
Clunking Noise On Right Side When Downshifting
Lexus ES300 / ES330 Forums rhkwon 3 92 Apr 4 2004, 03:52 PM
Last Post by: rhkwon
Vibrations
Lexus ES300 / ES330 Forums blake918 14 294 Sep 4 2003, 03:28 AM
Last Post by: amanda
My Es300 Shifts Like A Ford! (Pages 1 2 )
Transmission shifts HARD into overdrive Lexus ES300 / ES330 Forums dka551 20 389 Aug 28 2003, 09:40 PM
Last Post by: bbsal
I did the search, you gots to do the digging.
have fun researching.
steviej
95es 300-80k
I didn't think it was the dog bone again because I changed it a few years ago. Turns out I changed it 3 & 1/2 yrs ago and it was totally shot(BIGTIME) again.
Got part from my buddy today at toyota (Part #12363-62020) for $35 and fixed it in 10 minutes.
Here what I have had to repair in 3.5years and 43,000 miles(car had 37k when I bought)
CV joints
brakes
Engine move rod(Dogbone) twice
Replace power antenna
AC expansion valve(started blowing warm out of driver side vents before it totally went) Even when it did go,it would work fine until you drove for about an hour.
Thats it. Not bad.
How do you guys compare?
the oem dog bone doesn;t last long
get it checked or see how to check it yourself in the other threads with pics
I got tired of replacing mine so i made urethane ones which last and are much stronger
sk,
maybe you miss understood.
i changed dog bone today.
thanks though.
how long should it last?
i wonder how a solid dogbone would be.
