Ok,
I :blink: posted a thred last week about a strange loud noise coming from behind the dash/steering. It happened sparadically, and stopped.
Well this week that noise returned. This time the noise was accompanied by some electrical problems:
While driving on a 3-Hr drive, the radio started intermittantly cutting out, lights and musis, then I started hearing the noise (like airblowing inside a pipe) about 2 minutes later the VCS, ABS, BRAKE, and VCSoff Lights all lite-up and the VSC beeper tone came on constantly for about 3 minutes.
The car braked Fine, accelerated fine, shifted fine, steering fine, while the lights and buzzer were going off, then about 2 or 3 minutes into it the lights all turned off the buzzer turned off, and the car kept driving for another 1-1/2 hours.
The next day on the return trip, the same problem occured 2 more times.
I hooked up an ODBII scanner, and received no error codes.
Any Ideas?
Next step. the Lexus scan tool. There is a good posibility that there are codes in the computer that OBDII cannot read.
This topic is now closed to further replies.
