Mungrin Posted July 18, 2004 Share Posted July 18, 2004 Decided to take out my headlights and clean them out to get rid of fogging and condensation.As soo as i was done and put them back togther and put them in my car they instantly fogged up and its not raining or anything.I gues i will have to buy new headlights after all.What a bummer. Quote Link to comment Share on other sites More sharing options...
dcfish Posted July 18, 2004 Share Posted July 18, 2004 Make sure the seals around the lens is tight and drill 2-3 small holes 1/8th inch in the bottom and top of the assembly where they can not be seen and keep the lights on to disperse the condensation , this should CLEAR THINGS UP . Quote Link to comment Share on other sites More sharing options...
Mungrin Posted July 18, 2004 Author Share Posted July 18, 2004 thx,i will try that Quote Link to comment Share on other sites More sharing options...
Zigzag Posted July 23, 2004 Share Posted July 23, 2004 I tried the drilling solution, didn't work for long. Finally I attached rubber tubing (windshild washer type) to the drains( leave the vent alone) on each headlamp then routed it into the air inake box. Quote Link to comment Share on other sites More sharing options...
bobsvilla Posted July 25, 2004 Share Posted July 25, 2004 I tried the "reseal", didn't work for me either. I think I'll try Zigzag's method, the vacuum coming from the air box will lower the air pressure inside the headlite and should cause the moisture to evaporate. .....bob Quote Link to comment Share on other sites More sharing options...
