Is there a torque wrench that ill meet the majority of my needs for maintenance with my 98 GS 400? :blink: Thanks.
  • 3 weeks later...
I'd go with a 3/8" drive socket. They usually have a range of 10-75 ft lbs. Great for all the bolt / nut tightening specs. My Tire Lug nuts for 99 LS is 79 ft lbs, so I just go till it "clicks" and then another 1/8 turn more.
Get a "Dial" type wrench where the settings are on the shaft and you turn the dial up or down to select torque.
I do have three wrenches though, to be thorough:
5-200 inch lbs
10-75 ft lbs.
25- 150 fl lbs - 1/2" drive
Mine are Sears.........catch em on sale for around $45. Any brand will do though.
I have three Sears Craftsman torques too.
Just remember, whatever one(s) you buy slate, always set it back to STOP of 0 when not in use.
steviej
Thanks. I bought a Craftsman 3/8 20-105#. I need to zero the torque setting when not in use? Thanks for the heads up. I must have overlooked that in the instructions.
by setting it back to STOP or 0, it takes the tension off the internals.
just a shop tip I thought I would share with you to help maintain your new tools.
It is not required, just highly suggested.
steviej
  • 4 weeks later...
