Hello all
I have purchased a hirschmann replacement power antenna. I took the origanal out fine. The original has a relay that the harness plugs into and from the relay it plugged into the motor. The replacement has a red and white wire. the original harness has a blue and a black/yellow wire going to the motor. My question is this do I leave the realy hooked up and use the blue and black/yellow wires to hook up the new red and white wires? If so which one goes to which? I have tried the antenna using this and the antenna does nothing I have switched the wires on the red and white and still nothing. Do I need to take the relay out if so which wires do I use? thanks
I woulda tried replacing the mast first before I went off buying a new motor and all...usually it's just the mast that breaks, and they only cost like $15 from Pep Boys. :whistles:
