LS400er Posted June 13, 2004 Share Posted June 13, 2004 95, LS 400 - I observed last week that the two seat memory buttons and setting button are not working, Nothing happens when I press the buttons. Any body has any idea what could be wrong ? Thanks. Quote Link to comment Share on other sites More sharing options...
1UZ-FE Posted June 13, 2004 Share Posted June 13, 2004 have you used the memory seats before or do you know exaclty how to use them? theres a certain procedure explained in the owners manual of how to set memory positions and how to return the seat to the preset position. all actions to either set or move the seats to a preset position must take place with the car running or off, as long as it is in the "ON" position on the ignition. your foot must be off the brake pedal with the car in PARK. if you need more info on exactly how to set and return the seat to the previously set position, either read your owners manual or ask for more info. Quote Link to comment Share on other sites More sharing options...
LS400er Posted June 13, 2004 Author Share Posted June 13, 2004 I used the settings before and it ised to work fine. Any ideas ? fuse, connection, memory module ? Thanks. Quote Link to comment Share on other sites More sharing options...
acf Posted June 13, 2004 Share Posted June 13, 2004 You're holding down the set button while pressing either memory button? Sorry, If I insulted your intelligence with that. :whistles: Quote Link to comment Share on other sites More sharing options...
LS400er Posted June 13, 2004 Author Share Posted June 13, 2004 I do know the setting procedure. I am 100% sure its not working. Quote Link to comment Share on other sites More sharing options...
SW03ES Posted June 13, 2004 Share Posted June 13, 2004 One more thing, are you sure your foot isn't on the brake. Its automatic for me to put my foot on the brake when I'm sitting still with the motor running. When my dad got his LS400 I thought the memory seats were broken, but it was really just my foot on the brake. Thats unique to the LS400, my ES allows them to be moved when the foot is on the brake so does my Explorer. Quote Link to comment Share on other sites More sharing options...
LS400er Posted June 13, 2004 Author Share Posted June 13, 2004 I have tried again just now. looks like its Kaput. Any clues what must have gone wrong ? Quote Link to comment Share on other sites More sharing options...
SW03ES Posted June 13, 2004 Share Posted June 13, 2004 Probably the switch has gone bad... Have you checked the fuses? Quote Link to comment Share on other sites More sharing options...
LS400er Posted June 14, 2004 Author Share Posted June 14, 2004 No. How do I identify the fuses ? Quote Link to comment Share on other sites More sharing options...
90LS400Lexus Posted June 14, 2004 Share Posted June 14, 2004 Same thing happened to my 92' Buick Park Avenue. All of the power seat functions work properly, but the memory buttons will not respond. I think the switch is bad and that may be the case with your LS400. Quote Link to comment Share on other sites More sharing options...
SW03ES Posted June 14, 2004 Share Posted June 14, 2004 Do you have the manual? If so it should identify all the fuses... Quote Link to comment Share on other sites More sharing options...
rtbshome Posted June 19, 2004 Share Posted June 19, 2004 Same thing happened to my 92 LS400. It turns out because these buttons may be infrequently used the contacts develop some corrosion. The mechanic said just to keep trying them and eventually it will start to work. I spent about 1/2 hour just punching the buttons and eventually the beep reappeared and they worked again! Ever since then I make sure to change the settings occasionally. When you hear hoof beats think horses not zebras. Good Luck Quote Link to comment Share on other sites More sharing options...
1UZ-FE Posted June 19, 2004 Share Posted June 19, 2004 When you hear hoof beats think horses not zebras. ??? maybe this is totally random to me because its 3:30 AM but then again.... Quote Link to comment Share on other sites More sharing options...
blake918 Posted July 25, 2004 Share Posted July 25, 2004 My seat memory in my '95 is not working properly. When I push the different memory presets the mirrors and steering wheel move while the seat does absolutely nothing. The power seat works fine if I use the controls on the side of the seat, but the memory buttons make it do nothing. Any ideas?? Quote Link to comment Share on other sites More sharing options...
1UZ-FE Posted July 25, 2004 Share Posted July 25, 2004 just like we all asked LS400er, are you sure you know how the memory seats work? have you used them before and they just recently stopped working? Quote Link to comment Share on other sites More sharing options...
