bamalexusguy Posted June 12, 2004 Share Posted June 12, 2004 I recently purchased a 1999 ES300 Coach Edition with 65,000 miles. Everything works fine on the car except for the low beam on the headlights. The high beams and fogs work fine. Do you think it's only a fuse or relay or the unlikely event that both low beams burned out at the same time? My wife is hounding me to fix it!! Quote Link to comment Share on other sites More sharing options...
SKperformance Posted June 12, 2004 Share Posted June 12, 2004 do the taillights turn on? Quote Link to comment Share on other sites More sharing options...
lexusk8 Posted June 12, 2004 Share Posted June 12, 2004 You can check the fuses of the low beam bulbs. Refer to the owner's manual for the exact fuse locations. The low beam fuses should be found in the smaller fuse box located in the driver's side under the hood. If the fuses check out OK, then go ahead and check the low beam bulbs and make sure they're not burnt out. Just open up the hood, look for the electrical connector connected behind each bulb base and unplug, untwist the circular rubber grommet (just serves as a shield from any water or dust getting inside the headlamp), look for a spring clip which locks the base of the bulb into place and unhook and move it aside, and carefully pull the bulb out. FYI the bulb type for your car is H7. You will notice almost right away that the driver side is harder to work with considering there is less room than the passenger side, but it can be done. Hope this info helps. Quote Link to comment Share on other sites More sharing options...
bamalexusguy Posted June 12, 2004 Author Share Posted June 12, 2004 skperformance, yes the tail lights work. Quote Link to comment Share on other sites More sharing options...
SKperformance Posted June 12, 2004 Share Posted June 12, 2004 brake and taillights work right? they check your relay that turns it on in the engine bay area of the fuse panel or your switch is bad on the stalk unlikely but you may have burned both bulbs Quote Link to comment Share on other sites More sharing options...
bamalexusguy Posted June 23, 2004 Author Share Posted June 23, 2004 :P Finally got around to fixing the problem. It's hard to believe but both low beams were burned out. Thanks for the help!! Quote Link to comment Share on other sites More sharing options...
lexusk8 Posted June 23, 2004 Share Posted June 23, 2004 :P Finally got around to fixing the problem. It's hard to believe but both low beams were burned out. Thanks for the help!! Wow, that was a long shot for sure, but glad to hear you found that out and fixed the problem Quote Link to comment Share on other sites More sharing options...
