Diy Rx330 Oil And Filter Change
  • Please log in to reply
60 replies to this topic
#16 monarch
monarch
    Guru Member
  • Regular Member
  • PipPipPipPipPip
  • 1,402 posts
  • Model: LS 400
Posted 30 July 2005 - 10:27 AM
The 6 month, 5,000 mile service interval is the recommended MINIMUM allowable service interval required to keep the powertrain warranty in effect. It's an adequate interval to follow for owners who plan to sell / trade by the time the 6 year / 70,000 mile powertrain warranty expires.
However, owners who desire a troublefree Lexus for alot more years and miles should change the oil even more frequently.
Lots of first time Toyota / Lexus owners have unrealistic expectations. They expect a Toyota / Lexus to be troublefree for many years even if they do not keep up with the recommended MINIMUM allowable service intervals. These owners risk setting themselves up for a big dissappointment.
Have something to contribute?
Sign in or register to start a topic...
#17 doc777
doc777
    New Club Member
  • Members
  • Pip
  • 1 posts
  • Model: RX330
Posted 18 August 2005 - 06:13 PM
Great DIY set of instructions! I followed them step by step, and easily changed the oil. Thanks so much for posting such a comprehensive "manual," which made it so easy to help maintain my "magic transportation pod."
#18 Dave_02RX300
Dave_02RX300
    Club Member
  • Regular Member
  • PipPip
  • 92 posts
  • Model: RX300
Posted 10 November 2005 - 07:33 PM
Sorry to bug you all - after 20min of searching - is there a similar post for the 2002 RX300? Thanks -Dave
#19 Grumpa72
Grumpa72
    Advanced Club Member
  • Regular Member
  • PipPipPip
  • 353 posts
  • Model: rx330
Posted 06 December 2005 - 12:01 PM
:cheers:
Good job with the photos and stuff.
Has anyone figured out to clear the "service engine" light that comes on to remind you to change the oil? Mine is on and is annoying. This is not the check engine light that tells you the trouble codes.
Gary
'05 33
#20 docfnky
docfnky
    New Club Member
  • Members
  • Pip
  • 9 posts
  • Model: rx330
Posted 27 December 2005 - 01:15 PM
:cheers:
Gary
'05 33
To reset that light, take your keys out of the ignition, push down on the button that select between odometer and trip meter on the dashboard. while the button is still held down, put the key in the ignition and turn it to on (do not start the car). after that maintenance light turn off, you can let go of the button.
#21 chimchim
chimchim
    Club Member
  • Regular Member
  • PipPip
  • 89 posts
  • Model: RX330
Contributor
Posted 01 July 2006 - 10:44 PM
bumpity because I'm using my own DIY.
#22 steviej
steviej
    Guru Member
  • Management Team
  • 5,001 posts
  • Model: 2006 GS300 AWD
Posted 02 July 2006 - 07:26 PM
moved to tutorial section for safe keeping.
steviej
#23 Kutten
Kutten
    Club Member
  • Regular Member
  • PipPip
  • 49 posts
  • Model: RX330
Posted 28 July 2006 - 12:32 PM
This is an awesome DIY.. I should say, it's better than having a Lexus oil change manual.
#24 chimchim
chimchim
    Club Member
  • Regular Member
  • PipPip
  • 89 posts
  • Model: RX330
Contributor
Posted 01 January 2007 - 05:08 PM
Bump because I'm using my own DIY as a reference.
#25 Jhall143
Jhall143
    New Club Member
  • Regular Member
  • Pip
  • 12 posts
  • Model: RX300
Posted 05 July 2007 - 10:19 AM
Just what I was looking for...and with pictures? Wow. Thank you very much.
Jim --
#26 RX 330 Owner
RX 330 Owner
    New Club Member
  • Regular Member
  • Pip
  • 7 posts
  • Model: RX 330
Posted 05 August 2007 - 12:27 AM
How close are these instructions/photos to a 2005 RX330? ?
#27 ljpond
ljpond
    New Club Member
  • Members
  • Pip
  • 1 posts
  • Model: LX330
Posted 03 January 2008 - 08:23 AM
Wanted to add my thanks for your taking the trouble to post a detailed set of instructions with pictures. Recently purchased a 2004 and after getting the first service done for free, it was time to DIY. I did note the following:
1) the ground clearance was sufficient that I did not have to raise the vehicle.
2) while I did follow the instructions exactly, it is possible to access and remove the filter from above if you have the correct size end cap oil filter wrench for your socket set. I didn't but will get one for next time. Has anyone else done this and have any comment? I can't recommend this way yet since it might be necessary to remove the panel anyway to clean up oil that drips when you remove the filter. In a few thousand miles I will let you know if this was a good or bad idea.
Again, Thanks.
#28 randylindsay
randylindsay
    New Club Member
  • Members
  • Pip
  • 1 posts
  • Model: LS400, RX330
Posted 05 January 2008 - 01:06 PM
10) With the panel off, you can now see the oil filter (orange) and a nice gift from the Lexus engineers: an oil catch (green). Loosen the filter, and residual oil will drip out. The oil catch will guide the dripping oil out the oilpan/drainplug panel so position your oil catch below the catch.
Posted Image
11) On the new filter, dab a layer of fresh oil on the O-ring (the rubber ring around the outer lip of the open end of the filter). Align the threads of the new filter and spin it by hand onto the engine where the old filter was. When it makes contact, tighten by hand another 3/4 turn. Don't over tighten.
12) Wipe up oil drips. For me, even though the catch was there, some oil still dripped all over the exhaust pipe and panels. Wipe this up.
13) Fill the engine with 5w-30 oil, 5 qts. A funnel is helpful here.
Posted Image
14) Replace oil cap.
15) Replace both plastic panels.
16) Shut hood and drive around the block. Park the car on level ground and wait 15 minutes. Check for leaks and oil level.
I hope this is helpful to someone.
Thanks for an excellent post!
#29 mo.miner
mo.miner
    New Club Member
  • Regular Member
  • Pip
  • 4 posts
  • Model: 2004 RX330
Posted 06 January 2008 - 10:14 PM
Posted Image
Posted Image
#30 mo.miner
mo.miner
    New Club Member
  • Regular Member
  • Pip
  • 4 posts
  • Model: 2004 RX330
Posted 06 January 2008 - 10:30 PM
Great post...just exactly what I was looking for.
I did take off the wrong panel under the engine and should have taken off the smaller panel in front of the engine.
I would suggest that when re-installing that front engine panel, you should install the two forward bolts first which will help line up the other panel holes and makes it easier at least on my 2004 RX330. Mine wouldnt line up installing the bolts on the rear of the panel first. I wasnt really sure where the two sheet metal screws went as compared to the bolts. I put the screws on the very outside edge of this panel near the headlights.
What surprised me the most was the color of the engine oil when I drained it after 5,000 miles. It didnt appear that dirty on the dipstick but came out pretty dark in the catch pan.
I would have never found the oil filter without this posting. Even the owners manual didnt show it on the front side of the engine.
Keep up the great work with even greater photos.
MoMiner
Not what you're looking for?
Register now, we have a huge community of enthusiasts to answer any questions you might have
