All Activity
This stream auto-updates
- Today
navigation update for 2016 es350
ArthurW replied to Dorothy Pennachio's topic in 2013 - 2018 ES350 / ES350h
Oh nooo. How awful. 馃槦 The update process for me was in two distinct phases. The first step took about 20 minutes or so. The second step required an ignition switch off and switch on again (as prompted on the display) and then took another 6-7 minutes to complete. The SD card itself has a Lexus logo, so I assumed it was officially produced and not simply a copy by the dealer. The update reset all the settings and I had to spend some time retuning the radio, setting the navigation region, re-entering saved destinations, reloading customised images for the display, etc, etc. But all works as it should. Hope you can get it sorted. As an aside, the map is still a disappointment ... on the other hand, roads are constantly changing here in Dallas. I s'pose my obsession with having all my PCs and devices on the latest software/firmware level carried over to the car. In retrospect the upgrade didn't get me any noticeably new functionality, and I probably won't use the navigation much anyway (sticking to Google Maps on my Android phone). I'm glad it's done, but it certainly wasn't worth $215. -
lee24 joined the community
tomscot2 replied to Dorothy Pennachio's topic in 2013 - 2018 ES350 / ES350h
Thanks so much. It is interesting that the Lexus online parts site does not show this item as compatible with our cars. However, I looked up which radios are GEN08 and both the 2015 and 2016 ESs are GEN08. So I bought the same part number and it bricked my system. Neither the NAV nor the radio will boot. I'm still troubleshooting, and I have a call into the Lexus dealer. The fact that it worked on your car has me believing that I turned the car off in the middle of the process at a point where I thought it was done. 馃槥 - Yesterday
Mark_Orlando joined the community
I just went Black w/the Ecru interior, and they look great. I sourced mine from Bell Lexus in Scottsdale (on eBay) and they were $90 plus $15 FedEx Ground shipping. Comes w/4 retention clips. OEM # PT208-24010-02. Ordered Saturday and received Thursday. Others have mentioned Sewell is no longer a source and I'm not familiar with them except through this forum, so give Bell Lexus a try. I had a good experience.
pitchpopper joined the community
Brit - American joined the community
crystalm joined the community
200.000 mile club, anyone else there yet?
crystalm replied to jabowsi's topic in 04 - 09 Lexus RX330 / RX350 / RX400h
We have a 2008 lexus hybrid 400h and it has 257,000 miles and still runs great! We have had to put a little money it as far as new control arms, and alignment etc. She is a great car and I hope she lasts a lot longer! -
Ohhhh Even better idea! I could mount it to the sun visor and tap into the visor light for power! Good idea? Terrible idea?
- 4 replies
- solar trickle charger
- fusebox
(and 2 more)
Tagged with:
So, I'm one step closer to installing the trickle charger. Currently, I'm planning on tapping into one of the fuses in the driver's side internal fuse panel. Is there a problem with tapping into the main PWR fuse? Listed as fuse 32 here: https://www.startmycar.com/us/lexus/rx-400h/info/fusebox/2007 And listed as fuse 79 here: https://www.clublexus.com/forums/rx-2nd-gen-2004-2009/949043-windows-not-working-at-all-where-is-the-fuse.html My thought is to use suction cups or double-sided tape to connect the trickle solar charger to the window where the passenger sun visor goes. Then run the wire across the top of the window to the top of the drivers' side, then down the pillar and to the fuse box. Then connect to a part of the fuse panel that is always hot. Q: Any disastrous consequences? Q: Any better fuses or locations to tie into?
- 4 replies
- fusebox
(and 2 more)
Tagged with:
care_mentor_288 started following Timing belt or chain
care_mentor_288 replied to tak06's topic in 04 - 09 Lexus RX330 / RX350 / RX400h
My 07 RX400h has about 86,000 miles and hasn't had the timing belt changed yet... How concerned should I be? -
Marcos2023LC joined the community
Looking for a good PPF installer near LA or San Diego area.
DRACO A5OG started following Engine Immobilizer Reset
Worked like a charm for my 1996 ES300. Key in Driver Side Door, locked and unlocked several times, watched alarm light go off and on. Crossed my fingers and she started right up. After a rear end collision (not me, my son), car alarm went off and killed the car. Tried to remove battery and waited 10 minutes, connected, no joy, alarm started going off, auto locked the doors. 馃槥 Found this Post, tried it, Voila, it worked. I tried other tricks on YT to find the #4 & #13 Pin on OBD plug, no Joy only had #4. so for older 1MF-ZE engines with factory alarm, SKP's tips worked great. THANKS SKPerformance!
blindboi joined the community
- Last week
Fleet2jz started following 92 sc300 power steering pump bolt hole in ac unit
So on my 92 sc 300 one of the mounting bolts for the power steering pump is located in the ac unit. Well my ac unit bolt hole broke off and I don't want to replace the ac unit. Does anyone have an idea of how I can bolt in the power steering pump and still be able to to put tension on it without the ac unit?
RX400h started following Noisy dash fan
Fleet2jz joined the community
George B started following Noisy dash fan
I just bought a 2008 SC 430 with about 130,000 miles. The dash fan is noisy, too noisy to be normal and I can't figure out why. Doesn't matter if the AC or heat are on or off, something is going on in the dash making noise. almost sounds like gurgling water. Has anyone else encountered a similar problem?
George B joined the community
Sandboxman1972 joined the community
So, I have the same issue that the previous post mentions. I have sound. The nav system is working. However, none of the controls on the radio itself work (power, volume, etc.). Additionally the volume controls on the steering column do not work either. I can use the touch screen to adjust treble, bass, fade, etc.
Disconnect dinging seat belt sound
ArthurW replied to Norty Giffis's topic in 2013 - 2018 ES350 / ES350h
Yeah, agreed. For previous cars I've bought old seatbelt buckle keys from junk/scrap yards (the flat metal bit that clips into the seatbelt buckle). However, not a single one in my collection fits in the ES350, so I used the OBD scanner to disable the ding. -
In my case, nothing that I could do myself was helping for nearly 18 months (2 winters). I changed batteries twice, jump start many times in cold weather as well as during summer. I was very frustrated because even the dealer would not tell me how long it would take to find the source of drain but at bare minimum they would try for at least 2 hours @ 303/hour for a total of $606. My local mechanic refused to start the work because he said it takes long time with unpredictable results to find a drain. I think the dealer probably could find it quicker but they still wanted minimum 2 hour charge. Somehow I got lucky. I went to another Lexus dealer with my wife for an oil change on her car. And I asked the service tech about parasitic drain and indicated that I am willing to bring my car to work on the issue. But, first I want to know what is the most common reason for parasitic drain in Lexus and how much money I am looking at for that most common reason to fix so I am well prepared. He asked what year/model; I told him LS 430-2005. He said oh, many 05 LS 430 had amplifier causing the parasitic drain. And, if that is what he finds, it could cost anywhere upwards of $1300 to replace it in addition to 2 hour charge looking for the drain. So, I came home, watched YouTube to find out where the amplifier is in the trunk, removed the black cover and just unplugged the amplifier wire connector thinking that if this works, I could live without radio in this old car which I don鈥檛 listen to anyway. It was in the middle of winter with battery dying almost every 1-2 days. I kept my fingers crossed and started the car 2 days later and by good luck it started at first turn of the key. I waited 2 more days without driving so the car sat in the driveway for 4 days and started again on 5th day. Problem solved. Now I use my cell phone to listen to music and news. Navigation, and car phone audio still work on blue tooth. The only thing that does not work is radio and CD player. I would say just my good luck that I tactfully asked that question to the service tech otherwise everybody said "it could be anything, can't tell without starting the job".
Rhy400 started following 96 ls400 with water in the trunk please help
Rhy400 replied to 2smokey's topic in 90 - 00 Lexus LS400
I have a 99 here, I was able too locate the black hose and drain it on the passenger side but I was not able too find one on the drivers side, I know this is 5 years old but there is hope, thank you! -
Hi Tom. The invoice has partnumber PT219-GEN08-23. Invoice date is 5 April 2024. Attached is a screenie of the line item on the invoice. I asked for a discount and got a miserly $10.94 off the $210 list. The government of course required its pound of flesh and that pushed to nett price to $215.48. Also attached are snaps of the software nav/map update versions. Hope this helps. -
tomscot2 started following navigation update for 2016 es350 and 2016 ES300h nav update
Do you know the date of the actual map upgrade? I've heard that Lexus stopped updating the maps in 2019 or 2020. What was the part number? What is version number that shows in the nav. The version in me 2016 ES 300H is V15A8880. thanks -
Dean2 started following Disconnect dinging seat belt sound
Dean2 replied to Norty Giffis's topic in 2013 - 2018 ES350 / ES350h
The simplest way to get around the ding and the light are simple seat belt extensions. Put them in and leave them there. No more lights or dings. 15 bucks a pair on Amazon -
ArthurW started following Disconnect dinging seat belt sound
The Carista OBD2 scanner supports turning off the annoying seatbelt dinger for driver and/or front passenger on many Lexus models. Sadly the red dash seatbelt light remains on, but at least that awful government-imposed ding-ding can be silenced. Maybe a friend with a decent scanner can check whether your particular Lexus model is supported. -
Electrical system 2004 LS 430
Anthony Cartwright replied to Douglas Dieringer's topic in 01 - 06 Lexus LS430
Have you searched the fuse panels for the problem? There should be two panels, one on the driver's side (left foot), and passenger's side (right foot) areas. -
Thanks for this info, for I have the same issue.....
2000 Lexus ES300 is not shifting between 2-3 o the tachomete
RX400h replied to meema's topic in 92 - 06 Lexus ES250/300/330
A few possibilities from a Bing Copilot search:
Topics
