LexusUserV8 Posted August 31, 2022 Share Posted August 31, 2022 Hello, I have a 2017 LS 460 AWD with a brake actuator problem. My local Lexus dealership has been great working with me on this issue; within the last six months, they replaced the brake actuator twice and bled the brakes multiple times, per the guidance of Lexus (Corporate) Engineers and the TSB that applies to this situation. To my knowledge, there is no recall or actual fix yet for the brake actuator problem (thud noise when applying the brakes at lower speeds). If anyone has any recommendations and/or fixes, I will provide to my Lexus dealership for possible remedy of this ongoing issue. Standing by if additional info is needed from my end to help with a remedy. Thank you, Tom Quote Link to comment Share on other sites More sharing options...
RX400h Posted September 1, 2022 Share Posted September 1, 2022 I have read the same - There is no actual fix for this problem. Apparently, Lexus has revised the actuator more than once, yet have not been successful in permanently fixing the problem. I wonder if your dealership would loan you a car to use until a fix is designed. Quote Link to comment Share on other sites More sharing options...
LexusUserV8 Posted September 1, 2022 Author Share Posted September 1, 2022 Good evening, Thank you… it’s unfortunate b/c the vehicle is fantastic and I don’t understand how the issue was not fixed years ago as 2017 was the last model year for that LS 460 generation. They have provided a loaner when it was in, but I highly doubt a loaner until a fix is designed b/c of the uncertainty of the fix and timeframe… Quote Link to comment Share on other sites More sharing options...
LexusUserV8 Posted September 4, 2022 Author Share Posted September 4, 2022 In the interim, I will be working with the dealership to address front seat vibrations at various speeds; i.e.: 35-40mph and around 60-65mph. New tires and road force balance performed, so I am thinking it could be the driveline and/or some other issue. Maybe there’s an issue with the rear axle? No vibration with the steering wheel and drives straight as an arrow… If anyone has anything to share, I will bring it with me to the Lexus dealership next week. Thank you, Tom Quote Link to comment Share on other sites More sharing options...
RX400h Posted September 4, 2022 Share Posted September 4, 2022 More than a few of the 2016 model year LS460s have had suspension issues which include issues with one or more of the following (if applicable to this model): Shocks or struts ball joints Tie rods wheel bearings alignment Steering linkage power steering pumps and hoses wheel balance springs or torsion bars bushings electronic or air suspension A good alignment shop technician can pinpoint trouble areas, as this type of person has likely troubleshooted many vehicles with similar problems. Quote Link to comment Share on other sites More sharing options...
LexusUserV8 Posted September 4, 2022 Author Share Posted September 4, 2022 Thank you; I appreciate the information. I have an appointment for a test drive with the Lexus dealership/shop foreman next week. I assume that if he experiences the vibration in the seats then the dealership will be on board with looking further into my vehicle/situation. My vehicle is still covered under the certified pre-owned warranty. Do you have any information that is more specific or just present the aforementioned issues (you addressed in your last post) and see where they go with it? Quote Link to comment Share on other sites More sharing options...
RX400h Posted September 5, 2022 Share Posted September 5, 2022 I would let them look underneath to see if they can determine the root cause. Odds are that at least one of the aforementioned possibilities is causing the issue. Then again, they may have seen a particular issue in other customers' LS 460s that caused the same issues. Quote Link to comment Share on other sites More sharing options...
Ricmar00 Posted November 28, 2022 Share Posted November 28, 2022 Bought a 2017ls with 10k 2 years ago. After two visits for grabby brakes they said was normal, the actuator started chirping. FYI, I recognized it immediately since my 2007 needed a new actuator at 40k. Both were covered under extended warrantee and now CPO warranty 3 months later 36k, my actuator just started chirping again. Making an appointment to take it in today.. Still under CPO warrantee hoping they don't give me a hard time. Quote Link to comment Share on other sites More sharing options...
LexusUserV8 Posted December 29, 2022 Author Share Posted December 29, 2022 Hello Ricmar00, How did you make out? Quote Link to comment Share on other sites More sharing options...
LexusUserV8 Posted May 15, 2023 Author Share Posted May 15, 2023 Hello, I am following up to see if anyone has had any type of success with fixing the brake click noise on a 2017 LS 460 AWD? In reference to my previous post, the Lexus dealership has replaced the actuator several times; replaced the accumulator once; multiple brake flushes. When they performed the brake flush, they did not use the BG (or similar) machine and did not do a power flush. Since I still have the brake click noise, I’m wondering if a power flush then refill with dot 3 (or whatever is recommended) will solve the issue? Just throwing a dart here, but maybe the issue is nitrogen getting in the accumulator? Thank you, Tom Quote Link to comment Share on other sites More sharing options...
TMAC18 Posted June 22 Share Posted June 22 Well I was told there is nothing that can b done, & any fix is only temporary. Very frustrating. I drove a 1995 ls400 for 20 yrs & never a problem. It’s so frustrating listening to these brakes make that noise Quote Link to comment Share on other sites More sharing options...
