Zigzag Posted May 27, 2004 Share Posted May 27, 2004 Removed assembly from car, immersed in large tub of water (front up) no bubbles, spent over two hours with heat gun and blow dryer to remove ALL water traces and didn't the M___F___er leak again the first time it rained. It's gotta be the bulb gaskets. I'm *BLEEP*ed. :chairshot: :cries: Quote Link to comment Share on other sites More sharing options...
AWJ Posted May 27, 2004 Share Posted May 27, 2004 ziggy, try a search on this, mate. I found the best way to deal with this is to drill several small holes with the smallest drill bit you can find. Locate them in areas that will be invisible from a normal perspective. You light will no longer hold condensation. Quote Link to comment Share on other sites More sharing options...
