I have a 1995 ES 300. When if put the car in drive and give it gas there is a bump in the front end. I tested the motor mount which I believe is broken. Does anyone have any experience changing this out. Is this somthing that I would be able to do on my own (with help from a friend) or will it require special tools? Thanks everyone,
jim
which mount
upper or lower
common problem
i rebuild them using urethane and they last and are much stronger
It is most definitely your motor mount. Same symptoms as mine. Replacement had it running like new.
